Acceleration hesitation issue
Old 09-07-2013, 10:19 PM
tbrash's Avatar
Default Acceleration hesitation issue
Hello. I just bought a 2001 A6 2.7t Quattro and I am experiencing sporadic acceleration. Sometimes the car will accelerate just fine at full throttle and more often then not it will accelerate fine and then the RPM's will stop and accelerate slowly. Feels like it hesitates after a few second of acceleration. The rpms climb fast then stop and climb slow and it sounds like the car is trying but the turbos cut out or something. Anyone know what could be the cause of this? I guess I can try and video it next time I drive the car.
Old 09-08-2013, 04:14 AM
boost401's Avatar
Boost leak ..........any codes, is the cel light on?
Old 09-09-2013, 12:38 AM
tbrash's Avatar
There are no lights on. I haven't checked for codes, I have only had it for two days. Car runs fine other then poor acceleration.
Old 09-09-2013, 03:15 AM
GTA_Driver's Avatar
Scan the car for codes. That's your step 1, always.
Does your check engine light work, when you turn the ignition on (but don't start it)? Some have taped over the light.
Old 09-10-2013, 12:04 PM
tbrash's Avatar
A couple videos of what I am experiencing. One is accelerating while moving, the other is accelerating from a stand still. Does this seem like a Diverter Valve issue? I heard this is a common problem. I also hear a whistle, does not sound like the normal turbo sound. Also I took the main inlet Y pipe from on top of the motor off and there is oil residue inside. What would be the cause of this? Thank you for your input.
Old 09-10-2013, 12:08 PM
tbrash's Avatar
Sorry posted two of the same video. This is the one accelerating while moving.
Old 09-10-2013, 01:34 PM
sb_gli's Avatar
manual transmission? is your clutch slipping?
Old 09-10-2013, 01:36 PM
sb_gli's Avatar
nevermind, I see that it's an auto from the cluster.
Old 09-10-2013, 02:59 PM
tbrash's Avatar
Both videos are at full acceleration.
N'Syncro
33
02-16-2020 03:12 PM
Ariaze
09-03-2019 08:06 PM
anticsAK
09-06-2015 05:34 AM
englishe30
A4 (B7 Platform) Discussion
09-05-2015 05:34 AM
anticsAK
09-04-2015 09:59 PM
Quick Reply: Acceleration hesitation issue
