Old 09-06-2016, 11:42 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Audi A6 (C6) Interior Guides
Print Wikipost
Cabin Filter Replacement
Old 06-10-2009, 04:19 PM
ernestolopez's Avatar
Default Cabin Filter Replacement
Has anyone attempted to replace the cabin filters in the A6?-Where are they located,and does anyone have illustrations on how to replace them?
Also,is it an easy process to replace them?How will it effect the air quality in the cabin?Non smoker.
Old 06-10-2009, 07:47 PM
A6Gary's Avatar
Default There are two cabin filters on the C6, both are located...
behind the glove box, on the left side. You have to drop the glove box to R&R the cabin filters. Although I haven't done this maintainence yet on my '06 A6, the procedure in the Bentley Manual seems fairly straight forward and relatively easy.
Old 06-11-2009, 03:16 AM
05whtaudia6's Avatar
Here is a description on how to do it, many have done it DYI and I have not heard of anyone having any difficulties.
http://tech.bentleypublishers.com/se...n%20Filter.pdf
Old 06-11-2009, 05:41 AM
Bridgetown's Avatar
Default Reminder - Two filters needed
Found the process to replace the cabin filter straight forward. The glove box detaches after the removal of five 8mm screws. The link in this thread is helpful to locate the filters once the glove box is detached. Just reverse the process when replacement is complete.
Your A6 requires two identical filters to perform the task. I learned this the hard way and had to reorder another filter during the job.
As a non-smoker, I can not really tell if I improved my air quality. It just was just a task that I need to perform based upon the scheduled maintenance.
Hope this helps
Old 06-14-2009, 06:07 AM
Thanks for the feedback fellows!...Ernesto
Old 06-15-2009, 11:05 AM
The G Man's Avatar
Someone here had mention that you can change the HvAC filter by going in under the glove box. There is 1 panel there that can be remove and access the filters. Anyone here have try that yet?
bjterp00
S7
07-06-2020 11:01 AM
Dougie360
A7
12
12-11-2018 08:44 AM
sasikals26
A4 (B8 Platform) Discussion
06-05-2018 05:59 AM
RobertoM
Audi 100 / A6 (C4 Platform)
12-14-2006 12:06 PM
jbchinoca
07-31-2005 06:30 PM
Quick Reply: Cabin Filter Replacement
