Audi Original "S" Cars Discussion forum for the Audi Audi Ur S4, Ur S6, S2 & RS2
Detailed Power Output Stage (POS) info for those that care
Old 09-19-2005, 10:52 PM
UrS4boy's Avatar
Default Detailed Power Output Stage (POS) info for those that care
I needed to type this up anyway for the 1.8t coil pack instructions so I thought I would do it while there is POS "talk".
The AAN is a five cylinder car (Duh), therefore there are five spark plugs. The 3B before the AAN only had one coil and a more or less conventional Hall-effect distributor (c/w rotor and five wires). The engine engineers at Audi figured out that IF they provided each cylinder with its own coil, then the engine could make more horsepower (about 10 DIN hp more), bringing the nominal flywheel hp up from 217 to 227 hp (220 to 230 DIN hp). The trouble was they needed some kind of computer controlled switch to fire these coils in the correct order and at the correct time. Enter the POWER output stage or POS, not usually confused with piece of sh*t but eventually, yes, they all are. But I digress.
The AAN has two three channel POS units mounted on the firewall (they were made for six cylinder cars). See photo below for location (more info below the photo):
<img src="http://pictureposter.audiworld.com/86178/m_trap_urs4_-_labels.jpg">
These devices are named N 122 and N127. The N122 and N127 are just names. They are identical. Both have 4 pin inputs (for 3 ECU inputs and 1 ground) and 3 pin outputs (for up to 3 coils). What is important that for the POS with the four wires coming into it from the ECU, you have the 3 wire lead to the coils connected to it (3 = 1,2,3). Likewise, the POS with the 3 wires coming to it from the ECU needs to be connected to the 2 wire lead to the coils (2 = 4,5).
The primary coils wires are black and are labled with their cylinder number. They are NOT the input TO the coils as often thought. They are actually the outlet for the current flow FROM the primary side of the coils. The power feed TO the primary side of the coils are yellow wires that come from the two white three pin connectors on the metal connector rack on the firewall. The ignition-switched 12 V power is fed from the these connectors to the primary side of the coils. However, the primary side of the coil has no ground so normally there is no current flow or, as a result, spark. The ground is actually through the POS unit and pin 2/4 and its white-striped brown (BR/W) wire.
The ECU (engine management computer, with the aid of a signal from the crank position sensor (and cam position sensor during starting)), sends a 5 VDC (or so) signal to the respective channel on one of the POS's, Inside the POSs, there three transitorized swithes that, when triggered by the ECU's 5 V signal, send the 12 V current FROM the Primary coil to ground (through pin 2/4). With the "gate" open for current flow through the primary coil, this rush of current in the primary coil, "excites" the secondary coil which in turn produces a high voltage current that rushes to the nearest way out, which in this case is the spark plug.
The POSs fail because inside there are some very fine wires that seem to get brittle with age and/or heat. These wires break or crack, resulting in poor or intermittent current flow. We call that missing or hesitation.
Internally, in the POSs, Pin 1/4 connects to Pin 3/3, Pin 2/4 is a ground (brown with white stripe that eventually goes to the intake manifold), Pin 3/4 connects to Pin 2/3 and Pin 4/4 connects to Pin 1/3. Rember that. Draw a diagram if needed.
For POS N122, a green wire with a white stripe comes from Pin 1 of 55 in the ECU connector, representing Cylinder No. 1, and connects to Pin 4/4. The corresponding wire from the primary coils is connected to Pin 1/3 on the three pin side. A violet (purple) wire with a white stripe comes from Pin 2 of 55 in the ECU connector and connects to Pin 3/4 of N122, representing Cylinder No. 2. The corresponding wire from the primary coils is connected to Pin 2/3 on the three pin side. Pin 2/4 is the Brown with white stripe primary coil ground wire. A black with grey stripe wire comes from pin 23 of 55 in the ECU connector and goes to Pin 1/4 of the N122 POS for cylinder No. 3. The corresponding primary coil wire goes to Pin 3/3.
Got that? Good because that comes from the Bentley wiring diagram (pg. 24/X52), Scott Mockry's website (for the ECU pinout) and a convenient X-ray of a POS that I happed to have.
<a href="http://www.urq20v.com/My_other_cars/S6/POS/S6POS.htm">Link to the X-ray article</a>
Now it gets tricky. For the second POS, N 127, the Bentley is wrong. I will tell you the truth but you can easily comfirm what I say below by checking the wires yourself.
First, the ECU feed for cylinder No. 4 is a Black with yellow stripe from pin 20 in the 55 pin ECU connector. For No. 5, it is a black with white stripe from Pin 21/55 in the ECU connector. The tricky bit is the Bentley mislabled what happens to these two wires when they connect to the four pin side of the POS. The BK/Y (Cylinder no. 4) wire connects to Pin 4/4 (which is correct in the Bentley) BUT the Bentley shows the primary coil wire from Cylinder 5 going to Pin 1/3 on the three pin side. That is WRONG. Its primary coil no. 4 that goes to Pin 1/3 and primary coil no. 5 goes to 2/3, which corresponds to the black with white stripe wire from ECU 21/55 going to Pin 3/4 on the four pin side of the N 127 POS. As always Pin 2/4 on N 127 is the POS-switched ground for the primary coils.
If you were paying attention, Pin 1/4 and Pin 3/3 on N 127 are normally not used. This is the spare channel (the POSs were made for six-cylinder cars). This allows the potential to swap connectors and/or pins when one POS channel fails. For example, if you confirm that the POS for cylinder 4 is dead, you can move the wire in BK/Y for cylinder 4 in the four position POS input connector from 4/4 to the empty 1/4 position and then move the cylinder 4 coil wire 1/3 to the empty 3/3 position on the POS output connector.
When swapping the pins, pull the rubber boot back, away from the connector housing. Then push the purple pin holder out of the back of the black (or brown) connector housing. The purple pin holder has a little flap on one side. Lift it up. That will free up one retaining tangs of the female pin. Use a bent paper clip to push the tang on the other side of the pin in and then extract the pin out the back of the purple pin holder. Place the pin in the un-used position and close the purple pin-retaining flap. Load the purple pin holder back into the black (or brown) connector housing and return the rubber boot to its normal position. Re-attach the connector to the proper POS.
This 4 or 5 pin swap is is a one time fix. When the second channel fails, e.g. cylinder 5, you're done. You will need to buy a new POS.
This will be on the exam.
;&gt
Dave F.
Old 09-19-2005, 11:34 PM
popdemonic's Avatar
Default Thanks Dave.....
you've been helped me for this stuff once!!
UrS4boy
03-23-2012 02:41 PM
cparke
09-28-2010 06:32 AM
UrS4boy
15
09-29-2005 12:12 PM
Havepitty in W.Van
12
02-09-2001 09:32 PM
Quick Reply: Detailed Power Output Stage (POS) info for those that care
