| [Thread] [Post Followup] [Post Picture] [Search Forums] [Original "S" Cars Discussion] |
Seems to be a common issue on the automatic AWD trannys when a filter/fluid change is done on these. Fluid aerates and "rattles", this noise can be heard and felt in cooler lines to radiator. Some shifts may or may not be affected.
Many theories as to the cause: 1.) Aftermarket filters too restricted : disproven, same problem experienced when using OEM filters. 2.) Incorrect fluid used: disproven, same problem experienced when using OEM fluid or ATF III. 3.) Not enough room between pan and filter p/u: disproven too, people (myself included) have removed 1/4" from filter p/u and still have the problem. 4.) Leaking or misaligned seal on top of filter: again, disproven, no matter how perfectly you seal the filter, the fluid still aerates. 5.) Incorrect level of fluid: not the cause either, using the VAG tool to measure the level and temperature, the fluid level is perfect. Still has the problem, some have even tried more or less, no change. I talked w/ our tranny shop guy and he suggests tightening up the valve body bolts and or replacing the gasket above it (if it has one -which I'm trying to find out). An IATN post confirmed this could be the cause (leak in v/body gasket makes sense). And lastly, the infamous breather blockage. There's a breather somewhere on top of the tranny (not the one on the final drive...BTDT). So: Any pictures in KATE of breather on tranny? and, any part numbers on valve body seal or gaskets? Thanks everyone who's looking into this! It's much appreciated! -Many on the 100/A4/A6/A8 forums will thank you!!
Terms of Use | Copyright © 1996-2008 by AudiWorld. All rights reserved. |
