  • Original 'S' Cars FAQ Digest
  • Click here for your favorite eBay items
    [Thread] [Post Followup] [Post Picture] [Search Forums] [Original "S" Cars Discussion]
    Clarification needed on strut mount removal / source for self-locking nut
    Posted by: sligh93 on 2008-10-10 07:07:33
    Account #: 52145
    Clarification needed on specifically the self-locking nut and the use of the 3078 tool.
    Why do you need the ability to torque the outer nut and tighten the set screw at the same time? Couldnt you:
    (removing)
    1. undo the set screw, 7mm key
    2. undo the outer nut, 22mm socket
    and then..
    (replacing)
    3. torque the outer nut (with a conventional socket)
    4. tighten the set screw
    Is there something i'm missing or cant see while I'm imagining this procedure?
    Does anyone know a good source for the self-locking nuts? the bentley says to replace them after removal. I figure I could reuse them but I imagine them to be not so expensive.
    1992 S4 (1993 Canadian model year)
    RS2: Comp Turbo, MAF, EM, FIs
    26lbs Pastore software
    Stratmosphere bypass
    Eibach/Bilstein
    996tt calipers over 993tt rotors
    Stromung 3"
    1.8t coil upgrade
    17x8.5 SSR Comps w Eagle F1s
    Thread:
    Login with existing account
    Create a new account
