Turbocharger Coolant Pump (After run pump) leak
I found my slow coolant leak. The car has 118K miles. I found this part number on another post: <b>34 965 561 C</b>
Does anyone know if this can be repaired, or is it a replace-only deal. I don't want to eliminate it.
Here are some pictures for others who may have this problem in the future.
Top view of After run pump:
<img src="http://pictureposter.audiworld.com/4377/turbocoolantpumpbottomview.jpg" border="0">
Bottom view of pump with drip:
<img src="http://pictureposter.audiworld.com/4377/turbocoolantpumptopview.jpg" border="0">
Splatter on exhaust cross pipe:
<img src="http://pictureposter.audiworld.com/4377/splatteronexhaust.jpg" border="0">
More splatter on resonator/muffler/whatever:
<img src="http://pictureposter.audiworld.com/4377/splatteronmuffler.jpg" border="0">
Thanks for the attention.
can't be repaired - replacement is about $110
fap99 has them as do many others - very easy DIY. 15 min start to finish.
-jamie<ul><li><a href="http://fap99.com/item.wws?mfr=BOSCH&sku=BSH007840&price=111 .67&orpartno=1078888&cookieID=1Q50YRE9G26U 1DRM7T&drillid=9&image=http%3A%2F%2Fcatima ges2%2Esophio%2Ecom%2Fwebapp%2Fwcs%2Fstores%2Fserv let%2Fimc%2Fimag
Change it before it snaps the spigot off and leaves you stranded,,,
mine cost me 147.95 delivered to the door from autopartsway.<ul><li><a href="http://www.autopartsway.ca">http://www.autopartsway.ca</a</li></ul>
B5 S4 pump is cheaper and plug & play
The B5 S4 pump is slightly shorter so you'll have to play with the mounts a little bit, and the power plug is keyed differently so the metal retaining clip no longer works. My power plug has been held on only by friction and it hasn't come off in 2 years...
mine just went 3 weeks ago, but I needed the car & pd dealer $$ 8^(
.....it is a pretty easy fix though....although when removing it both the inlet and outlet tubes broke off (were fractured anyway, which was what was causing the leak to begin with) inside the rubber hoses. I had to crush them from the outside and pick the pieces out of the hoses. Be careful to extract all the bits if this happens to you.
