Audi Original "S" Cars Discussion forum for the Audi Audi Ur S4, Ur S6, S2 & RS2
Some pictures of my engine tear down.
Old 03-03-2004, 08:21 PM
fusilier's Avatar
Default Some pictures of my engine tear down.
Thought you guys might find this interesting.
<img src="http://www.bufkinengineering.com/front.JPG">
<img src="http://www.bufkinengineering.com/head2.JPG">
This is a good shot of the tapered water manifold.
<img src="http://www.bufkinengineering.com/head1.JPG">
<img src="http://www.bufkinengineering.com/block.JPG">
<img src="http://www.bufkinengineering.com/piston.JPG">
Pistons are 79.5mm Bore. 86mm stroke.
Head PN is 034103373K
Anyone notice anything strange about the head?
Old 03-04-2004, 02:19 AM
2DEDGE's Avatar
Default Re: Some pictures of my engine tear down.
Why does it have floating cylnders? Was it punched out and sleeves were put in? Oh no wait its aluminum!<ul><li><a href="http://movies.dvd2004.net/">http://movies.dvd2004.net/</a</li></ul>
Old 03-04-2004, 04:45 AM
YumyJager's Avatar
Default What is this?
A hole in the head above the #5 combustion chamber?
Old 03-04-2004, 05:10 AM
fusilier's Avatar
Default that is just a larger opening for water flow.
The extra machining in the head that follows the profile of the cylinders for water flow matches the machining in the alloy block. I was thinking that the head was a stock 3b, but it appears to by a matching sport head.
The cams were in perfect time, so I am concluding the ECU was not programmed for the obviously low compression judging by the dished cylinders which are not at all similar to standard 20V (9.3:1 CR) pistons.
There is nothing wrong with the block or head mechanically.
Old 03-04-2004, 06:46 AM
fusilier's Avatar
Default BIG pictures. Bandwidth warning. 6mp images
<img src="http://www.bufkinengineering.com/Engine_3576.JPG">
<img src="http://www.bufkinengineering.com/Engine_3577.JPG">
<img src="http://www.bufkinengineering.com/Engine_3578.JPG">
<img src="http://www.bufkinengineering.com/Engine_3579.JPG">
Old 03-04-2004, 06:59 AM
Riff's Avatar
Default Having never opened up one of these engines...
Isn't the water jacket around the cylinders awefully shallow? I have head about grouting a block to make the cyls stiffer, but this looks like there would not be enough coolant around the combustion area to keep the temps managable.
Old 03-04-2004, 07:05 AM
fusilier's Avatar
I think this block has improved water flow over a stock iron block.
eric7soccer
12-08-2008 03:13 PM
kixbax
02-24-2006 07:10 AM
fusilier
Quattro: Turbo / Ur / Sport
28
03-08-2004 04:17 AM
AFturboA4
05-02-2003 05:50 PM
SteveJ_in_TX
04-22-2002 12:03 PM
Quick Reply: Some pictures of my engine tear down.
