Frequently Asked Questions (FAQ), Procedures and Resources
#61
UrS Europrice SSK Install/General shift rod weighting
<ul><li><a href="http://www.audifans.com/twiki/bin/view/Audi/ShortShiftKitInstall">http://www.audifans.com/twiki/bin/view/Audi/ShortShiftKitInstall</a</li></ul>
#64
Mirror Switch Upgrade To Led
here's the link to a little howto
to change your lamps from the power mirror switch to leds...<ul><li><a href="https://forums.audiworld.com/s4s6/msgs/158261.phtml">link</a></li></ul>
#66
HVAC LED repair
from the A4 forum<ul><li><a href="https://forums.audiworld.com/a4/msgs/2589867.phtml">https://forums.audiworld.com/a4/msgs/2589867.phtml</a</li></ul>
#67
Part No.'s for the 993tt or 928GTS Brembo Big Brake Upgrade with RS2 brackets.
Credit to Trent Wakelin for these part numbers:
RS2 BRACKETS
8A0 615 125 A (034Motorsports or VAG Parts)
993tt Big Red Calipers:
993-351-425-10 (left), 993-351-426-10 (right)
Porsche 928 GTS front calipers
Porsche P/N -928-351-423-03 L, 928-351-424-03 R
Later A8 ROTORS (323x30, 5/112)
4D0 615 301 A or J (A was superceded by J)
Also:
Bolts, long (caliper to bracket, x4)
999.067.041.09
Bolt, short (Strut to bracket, x4)
N 100 880 03
Bolt size is: M12x1.25x25mm
Vibration dampers 44 mm (x4)
965 351 096 00
Vibration dampers 36 mm (x4)
964 351 096 01
Wear Sensors (x2)
993.612.368.00
Wear Sensor holders (x2)
928.612.361.00
Brake lines (x2)
443 611 707 C (rubber OEM, M-F, 405 mm long)
Or custom stainless steel
YMMV
RS2 BRACKETS
Also:
999.067.041.09
N 100 880 03
965 351 096 00
964 351 096 01
Wear Sensors (x2)
993.612.368.00
928.612.361.00
Brake lines (x2)
YMMV
#69
Heater Core Removal Trick from the A6/100 List
UrS-car owner and cool guy Mario Pott from the Bronx brought this to my attention. Looks like something we may all need at some point.
Enjoy.<ul><li><a href="https://forums.audiworld.com/a6100/msgs/71024.phtml">Procedure to remove heater core without removing the console</a></li></ul>
#70
S6 Plus / Euro center tail light instalation procedure.
<ul><li><a href="https://forums.audiworld.com/s4s6/msgs/118128.phtml">Link to S6 Plus / Euro center tail ight instalation procedure.</a></li></ul>
