Believe it or not, but there are over 200 parts in this picture!
#13
OK, here it is. Suspension rebuild parts list
qty description part number
1 engine mount left (Boge) 443 199 379D
1 engine mount right (Boge) 443 199 379D
4 engine mount bolt M10x42 N 010 441 4
4 engine mount lock nut M10 N 023 004 7
2 engine mount lock nut M10 N 102 090 05
2 transmission mounts 4A0 399 151 B
2 transmission mount lock nut M10 N 102 090 05
2 subframe bushings front 4A0 399 415 B
1 subframe bushings left rear 4A0 399 419E
1 subframe bushings right rear 4A0 399 420E
2 subframe bushing washer front N 904 799 01
2 subframe bushing bolt front M12x105 N 905 834 01
6 subframe bushing rear bolt M10x40x30 N 905 677 01
2 subframe bushing bolt rear M12x150 N 904 563 02
1 front track arm left 4A0 407 151
1 front track arm right 4A0 407 152
4 front lower control arm stabilizer bushings 4A0 407 181 A
4 front stabilizer washers 4A0 407 201
2 front stabilizer end nut M16x1.5 N 021 199 3
2 front track arm washer 4A0 399 347 C
2 front track arm sleeve 4A0 399 413 A
2 control arm ball joint pinch bolt N 034 778 4
2 control arm ball joint pinch nut M10 N 102 861 02
2 front wheel bearing 82 mm 4D0 407 625 E
2 "front coil spring for vehicles with sport-type running gear, 1 silver, 2 violet" 4A0 411 105 R
2 front upper coil spring dampening ring 2 lug 4A0 411 109
2 front inner stabilizer bushings 26 mm 4A0 411 327 G, 28 mm 4A0 411 327 J
4 front stabilizer inner mount nut M12x1.5 N 021 191 6
2 front shock bump stop 445 412 131
2 front shock dust boots 431 412 175 D
2 front upper strut bearings 4A0 412 249
2 front upper strut mounts 4A0 412 377 C
6 "nut, self locking M8" N 011 184 9
6 "nut, self locking M10" N 021 195 5
2 front shock top nut M14 N 022 150 6
2 Front strut Boge Turbo Gas 32-402F 4A0 413 031D
2 front CV boot kit inner 443 498 201 B
2 front CV boot kit outer 443 498 203 A
1 tie rod left 443 419 811 D
1 tie rod right 443 419 812 D
2 tie rod nut M12x1.5 N 021 191 6
2 rear wheel bearing 82 mm 4D0 407 625 E
2 rear CV joint boot kit inner 443 498 201 B
2 rear CV joint boot kit outer 443 498 203 D
2 diff front support bushing front 443 505 145 A
2 diff support bolt M10x60 N 010 460 7
4 self locking nut M10 N 902 856 02
2 trapezoidal arm rear support bushing 4D0 511 523 C
2 trapezoidal arm bolts M12x88 N 010 187 7
2 trapezoidal arm nuts N 021 191 6
4 trapezoidal arm bolts N 101 183 02
4 trapezoidal arm nuts M12 N 101 064 02
2 diff front support mount 443 511 277 B
2 diff front support bolt M10x70 N 100 575 02
3 self locking nut M10 N 023 004 7
4 washer 443 511 341 A
1 diff supprt bolt M10x95 N 101 733 03
4 trapezoidal arm bolts M14x105 N 102 985 01
2 trapezoidal arm bolts M14x65 N 010 197 7
2 differential rear rubber mount 183 199 381 A
2 trapezoidal arm front support bushing 4A0 511 247 B
2 trapezoidal arm front support bushings "8 teeth" 4A0 511 249
2 rear wheel bearing housing bushing 443 505 171 F
2 toe adjustment bracket bushing 443 505 171 F
6 "trap arm, front support nuts M12" N 906 386 01
4 washer 4A0 511 341 A
1 rear transverse track arm left 443 505 351 P
1 rear transverse track arm right 443 505 352 P
2 transverse track arm bolts M16x105 N 040 181 4
2 transverse track arm nuts M16 N 041 181 7
2 transverse track arm nuts M14 N 041 183 5
2 rear shock Boge Turbo Gas 32-115F 4A5 513 031 A
2 rear shock perch 443 512 103
2 "front coil spring sport-susp, 1 yellow, 3 blue" 4A5 511 115 AG
2 rear bump stop with cover 441 512 129
2 rear damping ring 441 512 297
2 rear bearing ring 441 512 331
2 rear stop ring 441 512 367
4 lock nut M12 N 012 191 6
6 "nut, M8" N 901 838 02
2 bolt M12x88 N 010 187 7
twopedalwarrior
07-06-2017 04:03 AM
kodeTT
12-07-2008 10:44 AM
Audi Logic
Audi 100 / A6 (C4 Platform)
12-19-2005 05:54 AM
