Believe it or not, but there are over 200 parts in this picture!
<img src="http://12v.org/urs/DSCF0325.JPG">
Doing a suspension overhaul, call me crazy, but I'm replacing pretty much everything:
- euro-spec sport springs
- Boge TG shocks, dust boots, bump stops
- engine mounts x2
- front subframe mounts x4
- front and rear strut mounts, bearings
- front track arms and related bushings
- sway bar bushings (inner and outer)
- front tie rod ends x2
- wheel bearings x4
- CV boot kits x4
- rear trapezoidal arm mounts x10
- rear track arms x2
- rear differential mounts
- rear diff seals (its leaking)
- transmission and rear diff gear oil (OEM)
- all associated hardware, lock-nuts, washers and bolts
Thanks to SJM and Autobahn (local supplier) for the parts.
- engine mounts x2
- wheel bearings x4
- CV boot kits x4
Good guess, a little more. Let's just say that my wife doesn't know.
All I told her was that "I'm going to buy some new springs and shocks".
Heehee
Heehee
I'm after a "stock-like ride", maybe a little stiffer and a bit more damped.
Hence the euro-spec springs and Boges TG. Besides, got the Boges wholesale.
I'm surprised you found the rear bump stops...
Mine were pretty shot, but the dealer said they were NLA. Had to duct tape the originals together and put them back in with the Konis...
