please help, i need to know what these codes mean, i need the engine codes deciphered
I changed my intake boot and found no tear in my TBB
VAG-COM Version: Release 504.1-UD Chassis Type: 8D - Audi A4 B5 Scan: 01 02 03 08 15 17 25 35 45 55 56 ------------------------------------------------------------------------------- Address 01: Engine Controller: 8D0 907 551 M Component: 2.7l V6/5VT G 0001 Coding: 06711 Shop #: WSC 06435 7 Faults Found: 16490 - Manifold / Barometric Pressure Sensor (G71) / (F96): Implausible Signal P0106 - 35-10 - - - Intermittent 18010 - Power Supply Terminal 30: Voltage too Low P1602 - 35-10 - - - Intermittent 17965 - Charge Pressure Control: Positive Deviation P1557 - 35-10 - - - Intermittent 17947 - Clutch Pedal Switch (F36): Implausible Signal P1539 - 35-00 - - 17539 - Oxygen (Lambda) Sensor; B2 S1: Internal Resistance too High P1131 - 35-10 - - - Intermittent 18062 - Please check DTC Memory of Instrument Cluster P1654 - 35-10 - - - Intermittent 16891 - Idle Control System RPM: Higher than Expected. P0507 - 35-10 - - - Intermittent Readiness: 0000 0000 ------------------------------------------------------------------------------- Address 03: ABS Brakes Controller: 8D0 907 389 E Component: ABS/ESP allrad D56 Coding: 04395 Shop #: WSC 06435 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Controller: 8D0 820 043 Q Component: A4 KLIMAAUTOMAT D58 Coding: 00160 Shop #: WSC 63351 No fault code found. ------------------------------------------------------------------------------- Skipping Address 15-Airbags ------------------------------------------------------------------------------- Address 17: Instruments Controller: 8D0 920 981 BX Component: B5-KOMBIINSTR. VDO D17 Coding: 02264 Shop #: WSC 08216 1 Fault Found: 01039 - Coolant Temperature Sensor (G2) 30-10 - Open or Short to Plus - Intermittent ------------------------------------------------------------------------------- Address 35: Centr. Locks Controller: 8L0 862 257 N Component: CV-Pump, Alarm, RC D16 Coding: 16140 Shop #: WSC 63351 5 Faults Found: 01367 - Central Locking Pump Run Time Exceeded (Likely Leak) 35-00 - - 01371 - Alarm triggered by Door Contact Switch; Driver's Side 35-00 - - 01374 - Alarm triggered by Terminal 15 35-00 - - 01370 - Alarm triggered by Interior Monitoring 35-00 - - 00956 - Key 2 09-00 - Adaptation Limit Surpassed ------------------------------------------------------------------------------- Address 45: Inter. Monitor Controller: 4B0 951 173 Component: Innenraumueberw. D03 Coding: 00102 Shop #: WSC 63351 No fault code found. ------------------------------------------------------------------------------- Address 55: Xenon Range Controller: 4B0 907 357 Component: LEUCHTWEITEREGLER D004 Coding: 00012 Shop #: WSC 63351 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Controller: 8D0 035 195 A Component: Radio D00 Coding: 00200 Shop #: WSC 63351 No fault code found. End -------------------------------------------------------------------------------------------------- |
