Need vacuum hose diagram
I am in need of the diagram that shows how the vacuum reservoirs are connected to each other. If someone here has it, I will forever be grateful
Cheers Edward |
Look right there on underside of the hood
Audi puts the vacuum diagram on a sticker. If it's not there, hood was likely replaced/repainted.
Thanks, I found it.
The diagram show both reservoirs connected to each other and then it goes to the main line that feeds from the intake manifold on the front of the engine, there is a T hose connector that is broken and the hose missing, so one of the reservoirs is connected and the other is not. The T hose connector broke and the white connector on the reservoir too, so I assume a small hose is missing. I purcahsed the car as an incomplete repair because they were not able to finish the repairs on a timely manner, and this is one of the details I need to finish. ELSAWin shows absolutely nothing on the vacuum system..... Cheers |
Modified Diagram
2 Attachment(s)
I finally figured out those vacuum lines. I hope this helps the next guy.Attachment 95827Attachment 95828
vacuum line
https://cimg3.ibsrv.net/gimg/www.aud...a685899a5b.jpg
vacuum lines front https://cimg9.ibsrv.net/gimg/www.aud...8e56c5d88a.jpg Rear vacuum hoses |
