With the addition of Menzerna to our line up I am offering a special discount to all you AW members
Hit me up with an e-mail.
20% off retail plus shipping (UPS Ground) payment via paypal All items below are now in stock: PO106FF----32 oz ---$49.95 - Nano Polish PO106FF is designed to repair a 2500-3000 grit sanding mark on new scratch resistant coatings in OEM applications. It is perfect as a haze and swirl remover after compounding on all dark colors. <img src="http://i46.photobucket.com/albums/f149/pyiu/menzerna_PO106FF_litre.jpg"> ----------------------------------------------- Super IP---32 oz ---$39.95 -SuperIntensive Polish is designed to remove 2000 grit marks on scratch-resistant coatings while leaving an excellent gloss finish. Suitable for all coating systems. ----------------------------------------------- IP----32 oz ---$25.95 - Intensive Polish is a high concentrate one-step polish for removal of 2000 grit sanding scratches on all fresh paint systems. <img src="http://i46.photobucket.com/albums/f149/pyiu/menzerna_PO91L_litre.jpg"> ----------------------------------------------- FPII----32 oz ---$25.95 - Micro Polish uses the highest quality finely milled powder to eliminate all haze, swirls, and holograms on all paint systems. Contains no fillers or glazing material to achieve a permanent ultra high gloss surface quality. ----------------------------------------------- Power Gloss----32 oz--PowerGloss Compound quickly and effectively removes 1000-1500 grit sanding scratches on all fresh paint systems. Leaves a high gloss finish in one step on all but the darkest colors <img src="http://i46.photobucket.com/albums/f149/pyiu/menzerna_S34A_litre.jpg"> ----------------------------------------------- FMJ----32 oz ---$49.95 -sealant <img src="http://i46.photobucket.com/albums/f149/pyiu/FMJ32oz.jpg"> phil@eastarsinc.com Thanks! Phil |
Phil, what can I use by hand?..I don't have a buffer
Thanks
If your going to bother to spend the $ on Menzerna quality, shell out for a PC
Phil - With the new labels showing the rotary, are some of these for rotary use only?
I currently use IP and FPII with a PC 7336 but I'm wondering if some of the other formulas would not work well with a PC? Any insight? One of the reasons I ask is that I have heard Optimum has reformulated some of their polishes for rotary use as opposed to PC use. Wondering if Menzerna is the same. Thanks.
hugj, nope you can use a PC these are the same as what is out there
in retail packaging but I'm only selling the commercial sizes 32 oz.
Steve, you can use the Adam's products by hand or
I still have few more Adam's Essentials Kits available or you can e-mail Detailers Paradise for their products.
e-mail me I will set you up with a great deal. |
Right, but any random orbital will work correct?
ygm ;-)
Which machine do you have?
yes it should work but you have to make sure you have the correct type of pads etc.
Just the labels are different actually the ones I have are newer than those
I just used that as reference, they are the same part numbers as the ones used by everyone out there.
I just buy them in 32 oz and there is no difference in product just the bottling. |
