Rusting Rotors Solution..........
Here is what my front rotors look like.......rust galore!
<img src="http://pictureposter.audiworld.com/81050/img_0950.jpg"> Into a plastic pan to remove the rust: <img src="http://pictureposter.audiworld.com/81050/img_0951.jpg"> I ran across this stuff from a Google search. Non-toxic, biodegrable, earth friendly, Evapo-rust. I bought 2 gallons at a local gun shop. He raved about the stuff. He does all his guns in it: <img src="http://pictureposter.audiworld.com/81050/img_0952.jpg"> The hubs had some rust on them so, 000 Steel Wool, cleaned with alcohol to remove any residue, studs taped off ready to paint(Dupli-Color High Heat 1200 degree flat black spray paint): <img src="http://pictureposter.audiworld.com/81050/img_0953.jpg"> Rusty rotors submerged in the Evapo-Rust solution: <img src="http://pictureposter.audiworld.com/81050/img_0954.jpg"> Rust all gone after just 1 hour. Rinsed with water and then air dried over night: <img src="http://pictureposter.audiworld.com/81050/img_0955.jpg"> Hubs all painted: <img src="http://pictureposter.audiworld.com/81050/img_0957.jpg"> Rear rotors are just as rusty: <img src="http://pictureposter.audiworld.com/81050/img_0959.jpg"> Nickel Anti-Seize: <img src="http://pictureposter.audiworld.com/81050/img_0960.jpg"> Putting Nickel Anti-Seize inside the rotor before I put it on the hub will prevent it from rusting to the hub, which just occurred on this forum by JXR on his 8-10-2006 post: <img src="http://pictureposter.audiworld.com/81050/img_0961.jpg"> Anti-Seize goes on the back of each pad: <img src="http://pictureposter.audiworld.com/81050/img_0962.jpg"> Front re-assembled: <img src="http://pictureposter.audiworld.com/81050/img_0963.jpg"> Rear rotor rust removed and painted: <img src="http://pictureposter.audiworld.com/81050/img_0964.jpg"> Rear rotor re-assembled: <img src="http://pictureposter.audiworld.com/81050/img_0966.jpg"> Wheel back on and no rust visible through the spokes of the wheel: <img src="http://pictureposter.audiworld.com/81050/img_0967.jpg"> I did this over a 3 day period. I am glad to get rid of the rust. Here is the link to Evapo-Rust.<ul><li><a href="http://www.evapo-rust.com/index.php">http://www.evapo-rust.com/index.php</a</li></ul> |
nice job and great writeup...thanks
1st class from start to finish.
Adding to tech.
Re: Rusting Rotors Solution..........
Neat.
You could also use the high temp silver. |
FYI: according to the evapo-rust site, they NOW carry this stuff at autozones nationwide
i will be getting it tomorrow. did you clean the stuff first to get the brake dust off or did you just dump it in?
I called 3 or 4 of my local Auto Zones and they told me........
they did not carry it nor could they get it.
I finally bought it at a local gun dealer, who by the way loves this stuff. I even talked to the President of Evapo-rust and told him about my trying to buy the gallon size at Auto Zone. |
I just dumped the rotor in a pan of Evapo-rust and let it work.
Took about 1 hour.
I did wash it off after taking it out of the solution. |
how much was the gallon? i bought some little ones
i have done my caliper carriers thus far. the stuff works great! good find.
i found a bin that will house my 345mm rotors so i am gonna dump em in tomorrow.
