Repost in Correct forum :VAG-COM fault codes =(, easy fix or workshop repair?
hi,
I had a fault with the air con (econ light wont switch off) and an airbag light always on, ran VAG-COM, it returned this.. any help would be greatly appreciated Car 2003 A4 1.8T quattro btw, is all of Address 17 regarding the radio? if so ignore that, aftermarket radio. Results.. Chassis Type: 8E - Audi A4 B6 Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76 Address 01 ------------------------------------------------------- Controller: 8E0 909 518 AA Component: 1.8L R4/5VT 0004 Coding: 0011701 Shop #: WSC 63351 1 Fault Found: 18043 - Powertrain Data Bus: Missing Message from A/C Controller P1635 - 008 - Implausible Signal - Intermittent Readiness: 0000 0000 Address 03 ------------------------------------------------------- Controller: 8E0 614 517 A Component: ABS/ESP allrad 1726 Coding: 04475 Shop #: WSC 06435 No fault code found. Address 08 ------------------------------------------------------- Controller: 8E0 820 043 H Component: A4 Klimaautomat 1116 Coding: 00000 Shop #: WSC 63351 3 Faults Found: 01810 - Actuating Motor for Temperature Flap: Right (V159) 41-10 - Blocked or No Voltage - Intermittent 00735 - Potentiometer in Positioning Motor for Air recirculation Flap (G143) 30-10 - Open or Short to B+ - Intermittent 00819 - High Pressure Sensor (G65) 30-00 - Open or Short to B+ Address 09 ------------------------------------------------------- Controller: 8E0 907 279 E Component: int. Lastmodul RDW 0305 Coding: 00001 Shop #: WSC 63351 No fault code found. Address 15 ------------------------------------------------------- Control Module Part Number: 8E0 959 655 B Component and/or Version: Airbag 8.4EP 2000 Software Coding: 0010602 Work Shop Code: WSC 63351 1 Fault Found: 01221 - Crash Sensor Side Airbag: Driver Side (G179) 012 - Electrical Fault in Circuit Address 16 ------------------------------------------------------- Controller: 8E0 953 549 F Component: Lenks?ulenmodul 0308 Coding: 00011 Shop #: WSC 63351 No fault code found. Address 17 ------------------------------------------------------- Controller: 8E0 920 950 K Component: KOMBI+WEGFAHRS. RB4 D36 Coding: 01400 Shop #: WSC 00636 WAUZZZ8E83A278285 AUZ6Z0B0292159 2 Faults Found: 01320 - Control Module for Climatronic (J255) 49-10 - No Communications - Intermittent 01304 - Radio 49-00 - No Communications Address 45 ------------------------------------------------------- Controller: 8E0 951 177 Component: Innenraumueberw. 0604 Coding: 00001 Shop #: WSC 00000 No fault code found. Address 46 ------------------------------------------------------- Controller: 8E0 959 433 BD Component: Komfortger?t TBF 1310 Coding: 06859 Shop #: WSC 63351 4 Faults Found: 01320 - Control Module for Climatronic (J255) 49-10 - No Communications - Intermittent 01616 - Signal Wire to Interior Monitor 49-10 - No Communications - Intermittent 01370 - Alarm triggered by Interior Monitoring 35-00 - - 01371 - Alarm triggered by Door Contact Switch: Driver's Side 35-00 - - End ------------------------------------------------------- thank you for your time barney |
