Confused by TPMS code, anyone help?
Hi guys, this may be slightly duplicitous, but I want to get my TPMS working correctly. The status quo is:
Car (2005 A8 4.2 shorty) has aftermarket 20" R8 rims on it, old (19" turbine) spare. The spare still has Sensor in it, the four rims do not, as I had them built up without as the VCDS says it couldn't reach the controller. I'm happy to replace all five with new orange, but can I test them/the receiver(s?) without installing everything? I've always had a TPMS icon on the dash. Autoscan results repeated below, always the same address 65 result.. I want to end up with an error free car, but first, TPMS working... thanks, K9 Tuesday,24,April,2012,14:11:05:40451 VCDS Version: Release 11.11.3 (x64) Data version: 20120401 -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 4E0 Scan: 01 02 03 05 06 07 08 09 0E 0F 15 16 17 19 25 34 36 37 38 42 46 47 4F 52 53 55 56 61 62 65 67 72 76 77 VIN: WAULL44E35N015651 Mileage: 232110km/144226miles 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: Malfunction 0010 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: Malfunction 0010 05-Acc/Start Auth. -- Status: OK 0000 06-Seat Mem. Pass -- Status: OK 0000 07-Control Head -- Status: Malfunction 0010 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: Malfunction 0010 0E-Media Player 1 -- Status: Cannot be reached 1100 0F-Digital Radio -- Status: Malfunction 0010 15-Airbags -- Status: Malfunction 0010 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: Malfunction 0010 25-Immobilizer -- Status: OK 0000 34-Level Control -- Status: OK 0000 36-Seat Mem. Drvr -- Status: OK 0000 37-Navigation -- Status: OK 0000 38-Roof Electronics -- Status: Malfunction 0010 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: Malfunction 0010 47-Sound System -- Status: OK 0000 4F-Centr. Electr. II -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: Malfunction 0010 55-Xenon Range -- Status: OK 0000 56-Radio -- Status: OK 0000 61-Battery Regul. -- Status: Malfunction 0010 62-Door, Rear Left -- Status: OK 0000 65-Tire Pressure -- Status: Cannot be reached 1100 67-Voice Control -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 76-Park Assist -- Status: Malfunction 0010 77-Telephone -- Status: Sporadic communication error 1000 ------------------------------------------------------------------------------- Address 01: Engine Labels: 077-910-560-BFM.lbl Part No SW: 4E0 910 560 J HW: 4E0 907 560 Component: 4.2L V8/5V G 0010 Revision: --H01--- Serial number: AUX3Z0E1759901 Coding: 0007773 Shop #: WSC 02313 785 00200 VCID: 2855C9C39BE83A9 1 Fault Found: 18061 - Please check DTC Memory of ABS Controller P1653 - 008 - Readiness: 0000 0000 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 09E-927-156.lbl Part No SW: 4E0 910 156 S HW: 09E 927 156 A Component: AG6 09E 4,2L5V USA 0020 Revision: --H01--- Serial number: 0054165 Coding: 0000002 Shop #: WSC 02313 785 00200 VCID: 32612BABAD34409 No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 4E0-910-517.lbl Part No SW: 4E0 910 517 B HW: 4E0 614 517 BC Component: ESP 5.7 allrad H44 0510 Coding: 0008597 Shop #: WSC 02313 000 00000 VCID: 2241DBEBFDD4D09 1 Fault Found: 01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30 000 - - ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl Part No SW: 4E0 910 131 HW: 4E0 909 131 D Component: FBS AUDID3 H04 0140 Revision: 01404004 Serial number: AUX3Z0E1759901 Coding: 0410624 Shop #: WSC 02311 785 00200 VCID: D8B539036B08CA9 Part No: 4E0 905 852 D Component: ELV 1834 No fault code found. ------------------------------------------------------------------------------- Address 06: Seat Mem. Pass Labels: None Part No SW: 4E0 910 760 C HW: 4E0 959 760 Component: Sitzmemory BFS H08 0060 Revision: 00000000 Serial number: 5DS 008 795-03 Coding: 3940448 Shop #: WSC 00000 785 00200 VCID: 234FDEEFE2CED91 No fault code found. ------------------------------------------------------------------------------- Address 07: Control Head Labels: 4E0-910-7xx-07.lbl Part No SW: 4E0 910 730 G HW: 4E0 035 729 Component: Interfacebox H43 1070 Revision: 00000000 Serial number: 346BD057520412 Coding: 0000000 Shop #: WSC 00000 000 00000 VCID: 244DDDF3E7C0DE9 Part No: 4E0 910 609 C Component: Bedienteil MMI H42 0100 3 Faults Found: 01325 - Control Module for Tire Pressure Monitoring (J502) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 5 Fault Frequency: 1 Reset counter: 21 Mileage: 230076 km Time Indication: 0 Date: 2012.03.13 Time: 19:01:13 00003 - Control Module 005 - No or Incorrect Basic Setting / Adaptation Freeze Frame: Fault Status: 01100101 Fault Priority: 5 Fault Frequency: 1 Reset counter: 71 Mileage: 231989 km Time Indication: 0 Date: 2012.04.21 Time: 08:38:45 01042 - Control Module; Not Coded 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 7 Fault Frequency: 1 Mileage: 1048575 km Time Indication: 1 ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: None Part No SW: 4E0 910 043 B HW: 4E0 820 043 D Component: KLIMAAUTOMAT 016 0400 Revision: 00000030 Serial number: 00000000062155 Coding: 1052993 Shop #: WSC 02311 785 00200 VCID: 1C3DE513DFB0E69 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 4E0-910-279.lbl Part No HW: 4E0 907 279 L Component: RLS NO RESPONSE Coding: 0123123 Shop #: WSC 02313 785 00200 VCID: 55ABB037FC1A771 Subsystem 1 - Part No: 4E1 910 113 B Component: Wischer WWS D3 H50 0400 Coding: 00000036 Shop #: WSC 02313 2 Faults Found: 02510 - Steering Column Adjustment 014 - Defective Freeze Frame: Fault Status: 01101110 Fault Priority: 3 Fault Frequency: 21 Reset counter: 11 Mileage: 0 km Time Indication: 0 01520 - Rain and Light Recognition Sensor (G397) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 96 Reset counter: 7 Mileage: 0 km Time Indication: 0 ------------------------------------------------------------------------------- Address 0E: Media Player 1 Cannot be reached ------------------------------------------------------------------------------- Address 0F: Digital Radio Labels: Part No: 4E0 910 593 B Shop #: WSC 00000 000 00000 VCID: 2649C7FB91FC2C9 ------------------------------------------------------------------------------- Address 15: Airbags Labels: 4E0-910-655-84.lbl Part No SW: 4E0 910 655 A HW: 4E0 959 655 E Component: Airbag 8.4E+ H10 0920 Coding: 0530707 Shop #: WSC 02313 785 00200 VCID: 244DDDF3E7C0DE9 2 Faults Found: 00588 - Airbag Igniter; Driver Side (N95) 002 - Lower Limit Exceeded - MIL ON 01587 - Igniter 2 for Airbag; Drivers Side (N250) 002 - Lower Limit Exceeded - MIL ON ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 4E0-910-549.lbl Part No SW: 4E0 910 549 HW: 4E0 953 549 A Component: Lenksäulenmodul H13 0040 Coding: 0012241 Shop #: WSC 02311 785 00200 VCID: E5CB00F72C7A671 Part No: XXXXXXXXXXX Component: Lenkradmodul H05 0080 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 4E0-910-xxx-17.lbl Part No SW: 4E0 910 950 G HW: 4E0 920 950 G Component: KOMBIINSTR. VDO H53 0210 Revision: D05 Serial number: AUDID3E1004444 Coding: 0016233 Shop #: WSC 08126 444 85715 VCID: 2855C9C39BE83A9 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 4E0-910-468.lbl Part No SW: 4E0 910 468 B HW: 4E0 907 468 E Component: Gateway H10 0080 Revision: 10 Serial number: 1900305217004F Coding: FCFE7BDD1B7904 Shop #: WSC 02313 785 00200 VCID: 2757CAFF96F6351 3 Faults Found: 01325 - Control Module for Tire Pressure Monitoring (J502) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 254 Reset counter: 76 Mileage: 230076 km Time Indication: 0 Date: 2012.03.13 Time: 18:55:42 02076 - Media Player Position 1 (R118) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 3 Fault Frequency: 237 Reset counter: 76 Mileage: 230076 km Time Indication: 0 Date: 2012.03.13 Time: 18:56:38 01303 - Telephone Transceiver (R36) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 5 Reset counter: 115 Mileage: 230483 km Time Indication: 0 Date: 2012.03.21 Time: 15:21:38 ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 4E0-910-131.lbl Part No SW: 4E0 910 131 HW: 4E0 909 131 D Component: FBS AUDID3 H04 0140 Revision: 01404004 Serial number: AUX3Z0E1759901 Coding: 0410624 Shop #: WSC 02311 785 00200 VCID: D8B539036B08CA9 Part No: 4E0 905 852 D Component: ELV 1834 4E0905852D ELV 1834 No fault code found. ------------------------------------------------------------------------------- Address 34: Level Control Labels: 4E0-910-553.lbl Part No SW: 4E0 910 553 H HW: 4E0 907 553 F Component: LUFTFDR.-CDC H06 4480 Coding: 0011310 Shop #: WSC 02313 785 00200 VCID: 2855C9C39BE83A9 No fault code found. ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr Labels: None Part No SW: 4E0 910 760 C HW: 4E0 959 760 Component: Sitzmemory FS H08 0060 Revision: 00000000 Serial number: 5DS 008 795-03 Coding: 4071530 Shop #: WSC 00000 785 00200 VCID: 234FDEEFE2CED91 No fault code found. ------------------------------------------------------------------------------- Address 37: Navigation Labels: 4E0-910-88x-37.lbl Part No SW: 4E0 910 888 C HW: 4E0 919 887 C Component: MNS US H44 0960 Revision: 00000000 Serial number: 378B-057517397 Shop #: WSC 02313 785 00200 VCID: 2E593FDBB90C649 No fault code found. ------------------------------------------------------------------------------- Address 38: Roof Electronics Labels: 4E0-910-135.lbl Part No SW: 4E0 910 135 A HW: 4E0 907 135 Component: Dachknoten D3 H02 0090 Serial number: 00000433500111 Coding: 0003477 Shop #: WSC 02313 785 00200 VCID: 1D3BE817C4AAEF1 1 Fault Found: 02153 - Sunroof Button (E325); Close 012 - Electrical Fault in Circuit - Intermittent Freeze Frame: Fault Status: 00101100 Fault Priority: 0 Fault Frequency: 1 Reset counter: 88 Mileage: 231136 km Time Indication: 0 Date: 2012.04.07 Time: 07:29:00 ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl Part No SW: 4E1 910 802 B HW: 4E1 959 801 B Component: Türsteuer.FS BRM002 0060 Coding: 0028204 Shop #: WSC 02311 785 00200 VCID: 2045D1E3F3D8C29 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 4E0-910-289.lbl Part No SW: 4E0 910 289 A HW: 4E0 907 289 Component: Komfortgeraet H04 0040 Revision: 00400004 Serial number: W040503010007 Coding: 0065086 Shop #: WSC 02313 785 00200 VCID: 2757CAFF96F6351 Part No: 4E0 910 853 Component: Heckdeckel H06 0050 Part No: 4E0 907 719 Component: Neigungssensor H03 0020 1 Fault Found: 01134 - Alarm Horn (H12) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 3 Fault Frequency: 254 Reset counter: 75 Mileage: 155710 km Time Indication: 0 Date: 2008.07.29 Time: 18:42:25 ------------------------------------------------------------------------------- Address 47: Sound System Labels: 4E0-910-223.lbl Part No SW: 4E0 910 223 K HW: 4E0 035 223 A Component: DSP-Amp.-High H13 0440 Revision: PROD_01 Serial number: 00000000011673 Coding: 0000016 Shop #: WSC 02313 785 00200 VCID: 254BC0F7ECFA271 No fault code found. ------------------------------------------------------------------------------- Address 4F: Centr. Electr. II Labels: None Part No SW: 4E0 910 280 A HW: 4E0 907 280 A Component: ILM Beifahrer H09 0040 Revision: Serial number: 00000000056576 Coding: 0010111 Shop #: WSC 02313 785 00200 VCID: 1E39EF1BC9ACF49 Part No: 4E0 910 511 A Component: UGDO HL US H02 0030 No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl Part No SW: 4E1 910 802 B HW: 4E1 959 802 B Component: Türsteuer.BF BRM002 0060 Coding: 0028204 Shop #: WSC 02311 785 00200 VCID: 2045D1E3F3D8C29 No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake Labels: 4E0-910-801.clb Part No SW: 4E0 910 801 C HW: 4E0 907 801 A Component: EPB A32C0220 H02 0220 Revision: A32C0220 Coding: 0000532 Shop #: WSC 08126 444 83438 VCID: 1F47D21FCEA6FD1 2 Faults Found: 02442 - Function Lamp in Control Head 009 - Open or Short to Ground - Intermittent Freeze Frame: Fault Status: 00101001 Fault Priority: 6 Fault Frequency: 171 Reset counter: 116 Mileage: 230112 km Time Indication: 0 Date: 2012.03.14 Time: 18:05:00 Freeze Frame: Voltage: 12.84 V Count: 65 02596 - Rear Brake Pads Worn 008 - Implausible Signal Freeze Frame: Fault Status: 01111000 Fault Priority: 6 Fault Frequency: 1 Reset counter: 247 Time Indication: 0 Freeze Frame: Voltage: 9.52 V Count: 61 ------------------------------------------------------------------------------- Address 55: Xenon Range Labels: 4E0-910-357.lbl Part No SW: 4E0 910 357 HW: 4E0 907 357 Component: Pre-AFS H01 0040 Revision: 00000001 Serial number: Coding: 0000001 Shop #: WSC 02311 785 00200 VCID: E2C11BEB3D54109 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Labels: 4E0-910-541.lbl Part No SW: 4E0 910 541 Q HW: 4E0 035 541 E Component: TUNER EU/US/RDW H42 0620 Revision: 00000000 Serial number: 396CP057505073 Coding: 0000002 Shop #: WSC 02313 785 00200 VCID: 2E593FDBB90C649 No fault code found. ------------------------------------------------------------------------------- Address 61: Battery Regul. Labels: 4E0-910-181.lbl Part No SW: 4E0 910 181 C HW: 4E0 915 181 C Component: J0644 BEM H12 0510 Revision: 00000000 Serial number: 00000000001930 Shop #: WSC 08126 444 00568 VCID: 2045D1E3F3D8C29 Subsystem 1 - Part No: 4E0 910 181 C Component: von VA0 0000000204 Coding: 344530393130313831432056413030303030303030323034 Shop #: WSC 12345 128 00289 1 Fault Found: 02256 - Quiescent Current 001 - Upper Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 7 Fault Frequency: 29 Reset counter: 116 Mileage: 230196 km Time Indication: 0 Date: 2012.03.16 Time: 04:18:01 ------------------------------------------------------------------------------- Address 62: Door, Rear Left Labels: 4E0-910-802.lbl Part No SW: 4E0 910 802 A HW: 4E0 959 801 C Component: Türsteuer.HL BRM002 0060 Coding: 0028204 Shop #: WSC 02311 785 00200 VCID: 1E39EF1BC9ACF49 No fault code found. ------------------------------------------------------------------------------- Address 65: Tire Pressure Cannot be reached ------------------------------------------------------------------------------- Address 67: Voice Control Labels: 4E0-910-75x-67.lbl Part No SW: 4E0 910 754 Q HW: 4E0 035 753 A Component: SDS 3501 US H45 0630 Revision: 00000000 Serial number: 00000502180131 Shop #: WSC 12336 024 394758 VCID: 346D2DB357204E9 No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right Labels: 4E0-910-802.lbl Part No SW: 4E0 910 802 A HW: 4E0 959 802 C Component: Türsteuer.HR BRM002 0060 Coding: 0028204 Shop #: WSC 02311 785 00200 VCID: 1E39EF1BC9ACF49 No fault code found. ------------------------------------------------------------------------------- Address 76: Park Assist Labels: 4E0-910-283.lbl Part No SW: 4E0 910 283 A HW: 4E0 919 283 B Component: Parkhilfe 8-Kan H12 0020 Revision: --.--.-- Serial number: 08720504000144 Coding: 0001208 Shop #: WSC 02313 785 00200 VCID: 2143D4E7F8D2CB1 2 Faults Found: 01628 - Sensor for Parking-Aid; Front Mid-Left (G254) 009 - Open or Short to Ground - Intermittent Freeze Frame: Fault Status: 00101001 Fault Priority: 3 Fault Frequency: 16 Reset counter: 116 Mileage: 230837 km Time Indication: 0 Date: 2012.04.02 Time: 14:05:46 01629 - Sensor for Parking-Aid; Front Left (G255) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 21 Mileage: 230076 km Time Indication: 0 Date: 2012.03.14 Time: 13:53:26 ------------------------------------------------------------------------------- Address 77: Telephone Labels: 4E0-910-336.lbl Part No SW: 4F0 910 336 A HW: 4E0 862 335 Component: Handyvorb2 H10 0120 Coding: 0010900 Shop #: WSC 02313 785 00200 VCID: 2143D4E7F8D2CB1 Part No: 4F0 910 336 A Component: Handyvorb2 H10 0120 No Faults Found or DTCs not supported by controller or a communication error occurred End --------------------------------------------------------------------- |
You will need to get the Tire Pressure Monitoring module (J502) online and communicating. Please check the repair manual but it looks like that unit is located under the rear seat - so I'd make sure it is plugged in and has the necessary powers/grounds.
Thanks Dana,
I've located the unit under the rear seat and it appears to be all plugged in and grounded appropriately. I'll get sensors replaced in all five wheels and see where we go from there.
Thanks, K9
Originally Posted by Dana @ Ross-Tech
(Post 24298369)
