Engine Dyno Plot of 1.8L bored to 1.9L on 24.5 PSI Boost.
<center><img src="http://pictureposter.audiworld.com/1185/18t35.jpg"></center><p>Audisport cams, GT35R plus other mods.
This setup was designed to run on a every day street car. More power is possible going to higher boost with suitable higher octane Fuel. |
very impressive lucas!
Fully Sick!
info on the cams? are they available to the states?
Re: info on the cams? are they available to the states?
Please talk to Jeremy at Matrix Integrated, he can help you out.
Torque line is impressive, shows a lot is left. Nice job, where does meth. inj. start -4500?
Re: Torque line is impressive, shows a lot is left. Nice job, where does meth. inj. start -4500?
starts at 21 psi.
Water injection is setup and run by boost level from the cooling mist controller. |
Re: Engine Dyno Plot of 1.8L bored to 1.9L on 24.5 PSI Boost.
Hey Lucas. Does your engine have a standard 1.8t block thats bored out? I didn't know that boring to a 1.9 would make a bigger difference in spool for a turbo that large. Thanks for the info.
thanks...will do
Its not my engine, its a engine we have finnished for a customer.
Its a Standard 1.8 block bored out to 83.5mm The Gt35R also has a 0.63ar exhaust. However the Cams we used seem to work really well. |
