1.8T vacuum tubing diagram despirately needed!
Hello. Can somebody please e-mail me with the vacuum tubing diagram for a '97 A4 1.8T. I'm removing my boost controller and trying to hook the vacuum tubing up to the stock configuration so I can run with a chip. I need a diagram for the turbo and blow off valve hook up to the engine and car. Thanks a lot!
Re: 1.8T vacuum tubing diagram despirately needed!
<center><img src="http://pictureposter.audiworld.com/AudiWorldPics/2000/Vaclayout.gif"></center><p>Hope this helps...I assume this is what you were looking for???
1-EVAP canister 2-From fuel tank 3-Evaporative Emission (EVAP) canister purge regulator valve -N80- 4-Check-valve for EVAP canister Between EVAP canister and intake manifold before turbocharger Installation position (light/dark side): Arrow points in direction of flow, as shown 5-Air cleaner 6-Turbocharger Check boost pressure page 21-46 7-Combination valve for secondary air injection (AIR) 8-Fuel pressure regulator 9-To power brake booster 10-Check valve Installation position (light/dark side): Arrow points in direction of flow, as shown 11-Vacuum booster 12-To Leak Detection Pump (LDP) 13-Vacuum reservoir 14-Distributor piece 15-Check valve Installation position (light/dark side): Arrow points in direction of flow, as shown 16-Secondary Air Injection (AIR) solenoid valve -N112- 17-Crankcase vent 18-Check valve Installation position (light/dark side): Arrow points in direction of flow, as shown 19-To tank Leak Detection Pump (LDP) -V144- 20-Check valve Installation position (light/dark side): Arrow points in direction of flow, as shown 21-Charge air cooler With charge air pressure sensor -G31- 22-Throttle valve control module -J338- 23-Recirculating valve for turbocharger -N249- Checking page 21-40 24-Intake manifold With Intake Air Temperature (IAT) sensor -G42 25-Pressure unit for boost pressure regulation 26-Wastegate bypass regulator valve -N75- 27-Mechanical recirculation valve Checking page 21-38 28-Pressure control valve for crankcase ventilation 29-Secondary Air Injection (AIR) pump motor -V101- Regards, James R. 2001 A4 1.8TQMSX-ESP On order, arrives Sept/Oct if I'm lucky. For sale 24,500 all mods listed plus all orig parts including turbo included in this price. 99 1.8TMS (Neuspeed K04, 5 Bar FPR, Beru Ultra X Plugs, K&N Filter, Remus Exhaust, S4 Wheel Well Liner Mod, Bilstein Sport Shocks, Neuspeed Sport Springs, Neuspeed Front Anti Sway, Brembo Rotors, Mintex Red Box, Ronal R-7's 17", 225/45/R17 Bridgestone S02 PP, Smartire (neat gimmick), Greddy Turbo Timer, European Projectors, Clear Sides and Full Tint...)<p> |
THANK YOU JAMES! That's perfect!
Cool, just like the gas company..."glad to be of service"
<p>
BTW 23,25,26 and 27 are the areas most likely to have been tampered with just FYI
<p>
James - Do you have the ECU maps for the 97 A4 1.8?
James-
Where do you get this great stuff from? This is awesome. By chance, do you have the ECU maps for the 1.8t? I need the maps eventually to hook up my A'PEXi Super AVC-R boost controller. Mostly need the maps to hook up the RPM monitor (I think). Thanks again! |
