I GOT FAULT CODES, HOW SHOULD I FIX
HOW SHOULD I FIX THEM?
(2000 A6 2.7T 6spd) MISFIRE : change spark plug only???? ABS : I don't know AIRBIG : I DON"T KNOW EGT : I DONT KNOW, maybe replace sensor?? CENT. LO : I DONT KNOW HELP ME OUT!! PLZ~~~~ AND ADVICE~~ THIS IS MY FIRST TIME USING VAG-COM I HAVE TO LEARN THANKS VAG-COM Version: Release 512.1-UD Chassis Type: 4B - Audi A6 C5 Scan: 01 02 03 06 08 15 16 17 18 34 35 36 37 45 55 56 57 67 75 76 77 ------------------------------------------------- Address 01: Engine Part No: 4B0 907 551 K Component: 2.7l V6/5VT G 0003 Coding: 06612 Shop #: WSC 02387 5 Faults Found: 18014 - Rough Road/Engine Torque Signal from ABS: Electrical Malfunction P1606 - 35-00 - - 17865 - Exhaust Gas Temp Sensor 2 (G236): Open or Short to Plus P1457 - 35-00 - - 16684 - Random/Multiple Cylinder Misfire Detected P0300 - 35-10 - - - Intermittent 16688 - Cylinder 4: Misfire Detected P0304 - 35-10 - - - Intermittent 16689 - Cylinder 5: Misfire Detected P0305 - 35-10 - - - Intermittent Readiness: 0000 0000 ------------------------------------------------- Address 15: Airbags Part No: 4B0 959 655 F Component: Airbag Front+Kopf 0002 Coding: 00406 Shop #: WSC 02335 1 Fault Found: 00588 - Airbag Igniter; Driver Side (N95) 32-00 - Resistance too High ------------------------------------------------- Address 35: Centr. Locks Part No: 4B0 962 258 J Component: Central Lock/Alarm D32 Coding: 15949 Shop #: WSC 05211 4 Faults Found: 01374 - Alarm triggered by Terminal 15 35-00 - - 01370 - Alarm triggered by Interior Monitoring 35-00 - - 01368 - Alarm triggered by Luggage Compartment Switch 35-00 - - 00956 - Key 2 09-10 - Adaptation Limit Surpassed - Intermittent |
suggestions....
Plugs....change if over 40k miles.
EGT sensor 2.....replace left EGT sensor (it's a bitch) is your airbag light actually on? don't worry about the contral lock codes |
Re: suggestions....
THANKS for help
BUT I REPLACED SPARK PLUG about 6 months ago CAN SPARK PLUG GONE IN SHORT PERIOD like 6 months? ALSO, MY AIRBAG LIGHT STILL ON HOW CAN I DO WITH AIRBAG?? |
then...
don't be concerned about the misfires, unless they recur after clearing the code. You still need to change the EGT sensor though. Misfires....maybe a touch of bad fuel, water in the fuel, or other minor issues.
Airbag, if there is a problem with the ignitor, then the whole drivers airbag needs to be replaced. In the meantime, removing the airbag, and using a contact enhancer, such as Stabilant, on the airbag connections could help. |
THANKS, first I WILL REPLACE EGT
