Dealer Service Codes
I posted this in the D3 forum and someone suggested I post here as well.
I'm looking at a 2003 S8 and have been given the dealer service codes by the used car dealer - but don't have the detail. Does anyone know how to get them? There are 11 entries, 4 are represented to me as routine service and the others as recalls. 6 visits total (no repeat codes) with the first looking like the date of sale so that puts it at one visit outside the scheduled maintenance. Below is what I got (sorry about the formatting.) thx DEALER DATE MILES R.O. O P E R A T I O N 408C10 11/18/05 34,511 6415 AM-0330 408B19 3/10/05 26,252 5279 AM-4638 408B19 3/10/05 26,252 5279 AM-0321 408B19 3/10/05 26,252 5279 AM-4636 408B19 7/8/04 18,523 95305 W2-9113 406A26 12/11/03 10,905 40423 AM-9227 406A26 12/11/03 10,905 40423 AM-0311 408B19 12/27/02 4,480 73727 W2-6824 408B19 12/27/02 4,480 73727 W2-6369 408B19 12/27/02 4,480 73727 W2-6329 408B19 10/3/02 900 70479 W2-9170 . |
I've got a link to a list of codes on my home machine.
Put a post in this thread after about 6PM EST, if you haven't gotten a response by then, and I'll see it and post it the link.
Here's a little better than half of 'em
AM-0330 30K mile service
AM-4638 brake pads rear AM-0321 ? AM-4636 front brake pads W2-9113 ? AM-9227 wiper blades AM-0311 ? W2-6824 ? W2-6369 refinish rear bumper cover W2-6329 front bumper cover W2-9170 ? |
Re: Here's a little better than half of 'em
I've pieced together most of the codes but am still missing W2-9170. From what I've found, it appears the last 4 digits are the most relevant.
FYI W2-9113 is GPS Antenna, W2-6824 is for sun visor replacement, AM-0311 is 11k service and AM-0321 is 21k service. When I'm done I'll post all the codes here for future reference. Any help would be great. thx . |
Here's the full list I had. (22k file cut'n'paste)
Keywords: Dealer service workshop codes
I've pinged a friend, to attempt to get an up-to-date version of this. >>From what I have seen, the codes we are interested in for our Audis begin a little ways into it - the first codes appear to be recall codes. I know from my printout that I got from Univ, that codes that begin with W are warranty and codes that begin with AM are maintenance items. So a code of AM 0345 is the 45k maint and a code of W 1001 would be an R&R the engine under warranty. RC GC-12 Idle Stabilizer Replacement RC GJ-12 Replace Throttle Switch in Audi Quattro RC GP-12 Replace Steering Lock Assembly in Quattros w/Airbags RC GS-12 AUDI DIFFERENTIAL OIL CHANGE TO SYNTHETIC RC GS-13 3spd A/T Replace Diff Oil RC GT-15 92 A100 vacumn hose modification hose to booster RC GT-16 92 A/T Replace Brake Vacumn Booster Valve Assy RC PC Transfer Pump RC PU A/T Starter Bracket RC PV A?T starter bracket RC QP-12 87-89 Jetta GLI 16Valve Right Front Brake line routing RC QX-12 90-1 Gti/Gli 16V Knock Sensor 034 905 377A RC QW-12 90 Jetta GLI fuel pump dev frm specs/replace 191201037S RC QZ Air duct cooling front brakes RC RC-13 Convienience Tools ie jack lug wrench screwdriver RC RG-12 Fuel Pump Corrado unit may come loose/replace as necc RC RL ??? Fox ??? RC RP-12 93 Passat Idle Stabilizer RC RS-13 New fuel tank w/ pump scirocco RC RW Bracket for Pre Heat Pipe RC RY Engine ECU/throttle clip/suction pipe--hesitate upshift RC RZ-15 Trans and Engine ECU Passat AND NEW SHIFT HANDLE RC SB Califonia Only Trans ECU RC SC California Only Trans ECU RC SD-12 HEATER CORE RC SF Replace Fuel hose and clamps 91-3 Fox RC SG-13 Replace Fuel Hose and clamps 93 Passat RC SH Fuel Hose and Clamps CORRADO RC SK Fuel hose and clamps DIGIFANT RC SQ-13 Secure Eng Comp elec wiring Corrado VR6 RC SW Replace both rear window regulators 92-4 Passat RC TB Cabriolet Fuel Tank, Spot Check Top, replace if leaking RC TC Airbag contol unit-California GIII RC TD Fox Heater Core bypass valve/underdash tray RC TF-13 95 Passat GLX Replace motor heatshield pre delivery RC TJ 93 Passat GLX/Corrado VR6 Cooling Fan RC QX 90-1 GTI/GLI 16VKnock sensor wiring reversed/new sensor RC VL NO VALID CAMPAIGNS FOR VW RC RZ Emissions recall 90-2 Passat new engine ECM/Trans TCM RC X... NO VALID CAMPAIGNS FOR VW RC XS Follow Up check of diff oil RC YS Follow up check of diff oil FM 0PDI Pre Delivery Inspection W 01A1 Pre Delivery Inspection W 01A2 30 Day Customer Satisfaction Consultation FM 01D3 Free Maintenance, O & F FM 0100 45 Day inventory inspect W 0101 2500 Mile Check W 0120 Pre Delivery Inspection W 0307 7500 Mile Service W 0315 15,000 Mile Service W 0322 22,500 mile service W 0330 30,000 Mile Service W 0337 (AM 0337) 37,500 Mile Service AM 0345 45,000 Mile Maintenance W 1001 Remove and Install Engine W 1009 Replace Engine Block W 1011 Replace Freeze Plug (coolant) W 1031 Replace Left Engine Mount W2 1033 Right Engine Mount W 1035 Replace right or other rubber engine mount W 1083 Replace upper engine cover-V6 W 1359 Rear Crank Seal..flywheel side W2 1360 R & R Flywheel, example RSJG A/T fro shims etc. W 1363 R & I torque conv drive plate W 1367 R & I Crankshaft needle bearing W 1372 Replace ribbed belt, presumably timing belt W5 1374 V-Belt W 1376 R & I pulley for belts W 1378 Belts W 1379 Install splash shield W 1514 R & R Camseal W 1520 Remove and Install Intershaft W 1523 Replace intermediate shaft oil seal W 1524 Adj Timing Belt 1527 Replace timing belt tensioner W 1550 replace one or all valve lifters 1560 Replace vale(s) or guide(s) 1570 Cylinder head R & I and or gasket 1571 Cylinder Head Gasket 1580 (W1580) Valve Cover Gasket W 1703 Check Oil Pressure w 1704 Oil Pressure Sender W 1705 Oil Pressure Sender W 1714 Oil Filler Cap Gasket W 1720 Oil pump and/or gasket W2 1724 Oil Pressure Relief Valve W 1751 Oil pan gasket W 1799 Low Oil Pressure Warning Switch W 1908 Radiator Fan Resistor W 1909 Radiator Fan Resistor W 1910 R & I Coolant Fan Control 1911 Replace low coolant level sensor W 1920 Radiator Fan Shroud W 1940 Expansion Tank 1950 Coolant Flange W 1957 Thermostat W 1958 Thermostat W2 1960 Coolant Pipe W 1962 Coolant Hose W 1970 R & I radiator presume for other service W 1975 Replace Radiator Cap W 1978 Temp Sensor W 2005 Fuel Filler Cap W 2015 Replace Fuel Gauge Sending Unit W 2022 R & I charcoal line includes slack tube test W 2038 Replace Fuel feed line W 2060 Replace Fuel Filter W 2064 Fuel Filter Area W 2065 Replace Fuel Pump Relay W 2066 Fuel Pump W 2080 R & I Accelerator Pedal W 23A1 Check diesel injection system W 24A1 Adjust CO Fuel Inj. models W 24A2 CO within specs, fine adj improves performance W 24B1 EFI diagnosis using VAG 1551 W 24C1 Digifant Check Throttle Body Adjust W 2404 CO Adjustment W 2417 O2 Sensor pulse relay 2425 R & I air cleaner housing W 2438 Replace intake air duct W 2440 Replace one or more injectors W 2441 R & I Fuel Distribution Rail W 2444 Throttle Body Switch Adj or R & R W 2445 Mass airflow sensor/airflow meter W 2447 R & I Intake manifold W 2462 Temperature Sensor W 2469 Replace Heated Oxygen Sensor W 2470 Replace ECU aka ECM W 2472 Replace voltage supply relay W 2481 Idle Stabilizer Valve W2 25A1 Injection System W 25A2 CO Within Specs, minor adjustment W 25B1 CIS Diagnosis w/ VAG 1551 W 2504 Injection System W 2510 Oxygen Sensors W 2511 Replace Fuel System ECU W 2512 Fuel Sustem ECM/ECU W 2514 Throttle Pos Sensor W 2519 Cold Start Modification A80, R & R Temp sensor/set co W 2527 Air Intake Elbow W 2542 Adjust Sensor Plate W 2544 R & I Throttle Body W 2549 Thermo Time Switch W 2555 Replace Fuel Pressure Regulator 2558 Idle Stabilizer 2560 R & I Fuel Distributor 2562 R & i Airflow sensor w/plate & Adj/set CO W 2568 Replace Idle Air Control Valve (Vacumn Switch) 2574 Throttle Switches 2580 R & I Upper Intake manifold--presumably to replace Valve Cover Gasket W 26A1 Complete Exhaust System W 2610 Replace Exhaust manifold gkt 2615 R & I Exhaust Heat Shield 2616 Front exhaust pipe Gasket 2617 Front exhaust pipe 2621 Exhaust Clamp W 2630 Replace main (rear) muffler W 2632 Mid muffler W 2633 Replace rear muffler W2 2638 Exhaust Hanger W 2673 Replace CAT Conv. and or replace and or weld heatshield W2 2686 Exhaust Emission W 2706 Battery charge or replace W 2720 Charging System relaTED/POSSIBLE TEST W 2722 R & R Alternator W 2728 Alternator Mounting Bracket W 2760 R & I Starter W 2782 Replace cruise Control Unit W 2783 Cruise Switch W 2790 Cruise Vacumn Vent Valve W 2791 Vacumn Hose Cruise W 2804 Replace Electrical part of Ign sw W 2807 Ignition Lock Clyinder W 2810 Replace steering lock switch W 2815 Ignition Buzzer Relay W 2820 Replace Ignition Coil W 2825 Ignition module W 2830 R & I distributor assy, inc. set timing W2 2832 Distributor Cap and Rotor W 2834 Replace distributor rotor W 2839 Replace cam position sender with distributor removed W 2853 Spark Plug Wire or Wires W 2870 Replace Spark Plugs W 2872 Knock Sensor W 2873 Engine Speed Sensor W 3005 Replace Clutch Pedal Pad W 3010 Replace self adjust clutch cable W 3012 Replace Clutch Cable W 3052 R & I Clutch Pressure plate W 3056 R & I clutch W 3247 R & I torque converter seal W 3404 Replace Shift knob W 3406 Replace Shift boot W 3417 R & I Gearshift Knob W 3420 Shift linkage W 3435 R & I complete transmission W 3437 Replace transmission housing W 3462 Differential lock switch W 3548 Replace Transaxle Rear Main shaft brg W 3550 Replace transmission mainshaft seal-trans removed W 3572 Replace second gear set W 3575 Replace 5th gear set W 3577 Replace Gear Idler W 3581 Replace 1st/2nd clutch gear W 37A1 A/T Diagnosis using VAG 1551 W 3704 Replace Gear Selector Knob W 3706 Shift Ind Light W 3724 Transmission gear display with pigtail & connector W 3730 Replace A/T Control Module W 3731 Replace multi function trans switch W 3732 Replace Vehicle Speed Sensor W 3735 Perfomance Test Transmission W 3756 Transmission Housing W 3788 Replace shift lock relay ie for starter interlock W 3856 ATF Pump W 3858 ATF Filter W 3864 Trans 1st gear brake piston W 3901 COMPLETE FINAL DRIVE W 3908 Replace Ring and Pinion gearset W 3912 Replace Differntial side gear W 3922 Drive Flange Oil Seal W 3929 Output shaft seal W 3932 Replace Transmission side output shaft oil seal W 40A1 Complete Suspension W 4007 Subframe W 4017 R & I one lower control arm W 4020 Front Control Arm bushing W 4036 R & I lower BJ W 4041 Replace Driveshaft W 4044 Air Intake Elbow W 4045 Diagnose CV Joint W 4048 Outer CV Boot W 4050 Wheel Brg Hsg/Front Steering Knuckle W 4057 Front Wheel Brg W 4075 R & I Both Front Coil Springs W 4088 Strut Top Brg W 4090 Shock Absorber W 4211 R & I control arm W 4233 R & I one stud axle W 4268 R & I Wheel Hub W 4293 Rear Struts W 4405 Balance Tires W 4410 Replace one steel wheel W 4440 Replace Tire W 4485 Alignment W2 4490 Rear Wheel Alignment W 4495 Check Front and rear Alignment W 45A4 ABS Diagnosis using ABS 1 Tester W 4511 Right Front Speed Sensor for ABS W 4515 ABS L/Rear speed sensor W 4545 Replace ABS Control unit W 4605 Replace brake pedal W 4609 Replace brake pedal return spring W 4615 Rear brake backing plate W2 4617 Brake Splash Shield W 4623 Rear brake shoes W 4636 (AM 4636) Front Brake Pads W 4638 Brake Pads Rear W 4650 Front Brake Rotors W 4653 Rear Brake Disc W 4665 E Brake Lever Cover W 4672 Handbrake Handle Rachet W 4679 E Brake Cable W 4690 Parking Brake Warning light switch W2 4708 Brake Fluid service W 4711 Brake Fluid Cap on Master Cylinder W2 4714 Master Cylinder Plug W 4715 Master Cylinder W 4737 Replace one wheel cylinder W2 4741 Rear Caliper W 4750 Brake Pressure Regulator W 4768 R & R Brake Pressure Accumulator W 4770 Power Brake Vacumn Booster W 4775 Power Brake Vacumn Check Valve W2 4776 Brake Vacumn pump W 4810 R & I steering wheel W 4812 R & I Horn ring cover W 4813 Column Cover Horn Area W 4814 Upper Steering Shaft W 4818 R & I height Adjustable steering column W 4879 r & i tie rod(s) W 4885 Powersteering Belt 4890 Power Steering Gear 4894 R & I PS pressure hose 4895 R & I PS return hose 4897 R & I PS Fluid Resevoir 4898 R & I Ps pump,likely to replace belt W 5355 Install Stainless Steel plug (in rear quarter panel?) W 5514 Adjust Hood release cable AM 5517 Hood Latch Mechanism 5518 Door Latch W 5530 Replace hood support prop rod 5534 Replace central locking actuator W 5556 Rear Trunk Lid Lock W 5557 Replace rear lid grip w/lock push button W2 5558 Trunk Lot Cylinder W 5559 R & I Rear lid/Liftgate W 5573 Trunk lock actuating rod W 5585 NG hoods/lid W 5708 Replace infared transmitter key battery/bulb W2 5709 Door Lock Cylinder replace and match tumblers W2 5711 R & I exterior Door Handle 5717 R & I one or both front door handles 5721 Repalce door lock W 5725 Striker Pin Front Door W 5737 Door Pull Cable Inside Door W 5745 Door Release Lever W 5753 Adjust door hinge W 5759 Door Check Rod W 5763 Inner Door Seal Front W 5775 Replace 1 Front door Central locking Actuator W 5776 Power Door Lock W 5780 Central Lock Pump W 5811 Rear door handles W 5817 Left rear door lock W 5821 Rear door lock knob button W 5826 Striker Pin Rear Door W 5837 Pull rod cable rear door W 5845 Replace inside rear door operating lever W 5863 Inner Door Seal Rear W 6012 Sunroof Switch W 6013 Sunroof Relay W 6014 Sunroof Motor Gearbox W 6018 R & I Sunroof control cables--includes adjustment W 6023 Sunroof gear cover W 6028 Sunroof guide frame W 6033 Sunroof Wind Deflector W 6036 Sunroof Wind deflector linkage W 6040 Sunroof Panel W 6042 Sunroof Weatherstrip W 6051 R & I lower sunroof frame W 6310 R & I Front bumper cover presumably for refinish W 6329 Front Bumper Cover W 6369 R & I rear bumper cover presumably to refinish W 6370 Rear Bumper Moulding W 6414 Replace Windshield W 6416 Windshield Weatherstrip W 6420 Inner windshield mldg W 6441 Replace front window glass W 6442 Replace vertical rubber seal door glass W 6445 Front Window Weatherstrip W 6448 Replace outer front door window slot weatherstrip W 6450 Power Window R & I ECU W 6453 Manual front window regulator W 6454 Window Regulator Motor W2 6455 Glass-Electric Front Window Regulator W 6458 Power window switch W 6459 Rear Window Lock Out Switch W 6471 Window Frame, Regulator or Motor Adjust or Replace W 6476 Replace rear side window weatherstrip w/glass removed W 6489 Rear tinted window glass W 6492 Rear Defog Switch W 6603 Remote Mirror W 6607 Replace Grill emblem W 6617 Fender Side Panel Moulding W 6619 Side Mldg W 6621 Front Door Moulding W 6631 Flared rocker panel moulding W 6633 Replace 1 Front trim mldg W 6641 Replace rear door mldg 6650 Replace rear deck model emblem ie "jetta" W 6651 Replace rear insignia W2 6657 Left Remote Switch For Mirror 6658 Remote Mirror Control 6678 L or R Door Mirror Glass 6679 Replace left or right side mirror W 6680 Remote mirror adjuster W 6820 Front Ashtray 6683 Front license plate trim W 6727 R & I Stereo Radio W 6728 Replace Stereo Cassette W 6805 Replace inner sill panel mldg W 6812 Glovebox door W 6815 R & I Glovebox W 6817 Center console W 6818 Knee Bar Surrounding Console,Possibly to access shifter W 6823 R & I One or both sunvisor (s) W 6827 Rear View Mirror W 6835 Replace chicken handle W 6858 Replace timed seatbelt sender W 6867 Air Bag spiral spring W 6876 Rear three point seatbelt W 6877 Rear Seatbelt?? W 6878 Interior accessories W 6879 Inertia Lap Belt W 6884 Seatbelt interlock related W 6885 R & I Safety Belt lock contact (likely for warn light) W 7003 Trim--Luggage Compartment W 7014 Replace Speaker Grill W 7018 R & I Instrument Panel W 7030 Rear Shelf Trim W 7041 Replace front carpet W 7057 A Pillar Trim W 7058 Instrument panel wood trim W 7059 R & I front door trim panel W 7062 Replace inner door plastic seal W 7063 Replace one inside door pull handle/armrest W 7067 B Pillar Trim W 7068 C Pillar Trim W 7069 D Pillar trim W 7073 Replace one door (trim) Panel W 7084 Sunroof W 7086 Replace or reglue sunroof panel headliner W 7092 Rear Lid Trunk Trim W 7211 Replace one seat slide W 7231 Seat Backrest Adjuster Knob w/trim W 7246 Replace front seat backrest W 7291 Replace Electric Seat Relay 7412 Front seat cover upholstery 7420 Front seat back upholstery W2 7426 Seat Heater Switch W2 7427 Seat Heater Relay W 7428 Front seat heater harness W 7429 Front seat backrest heater harness W2 7456 Ski Boot W 7686 bad code vanagon stove W 8013 Heater control cable W2 8015 Heater Control Valve W 8023 Replace Heater Core W 8030 Replace valve to heater core hose W2 8032 Heater Core to Engine Hose W 8510 Replace heater and fresh air controls W 8516 Fresh Air Flap W 8525 Fresh air blower series resistor W 8553 Replace center air outlet (dash vent) W 8555 Front footwell heat outlet W 87A2 A/C Diagnosis W 8702 Replace A/C controls W 8704 R & I A/C Control Unit W2 8710 Blower Motor Switch W 8712 Replace Thermostat Switch for A/C W 8715 Replace A/C Wiring Harness W 8725 Check or replace V Belt W 8727 A/C COmpressor Clutch Relay W 8734 Replace A/C Compressor W 8745 Replace Suction Hose W2 8748 Heater Programer W 8750 Replace Condensor W 8755 A/c Receiver dryer W 8760 R & I Evaporator Assy W 8786 Replace Vacumn Resevoir W 8791 Drain hose--assume for a/c W2 9003 Instrument Housing W2 9006 Speedo Change W 9007 Repace mile counter lower cable W2 9008 Speedo Cable related W 9023 Fuel Gauge W 9027 Replace LED indicator W2 9028 Circuit in Instrument Panel W 9029 Replace Voltage Stabilizer Cluster removed W 9032 Tach W2 9034 Check Package W 9045 Replace Multi Function Indicator Lamp W 9050 Replace Alarm System Horn W 9052 R & I horn W 9059 Horn Relay W 9062 R & I Cigar Lighter Socket W 9096 Replace alarm system rear lid/liftgate switch W 9133 Radio W 9134 Radio Stereo Cassette, replace W 9135 Radio, premium-replace W 9138 Antenna 9139 radio or antenna related W 9141 Replace front speaker W 9142 Replace rear speaker W2 9184 Window antenna Amp W 9205 Wiper/Washer W 9215 Replace Wiper Motor W 9219 R & I W/S Wiper Linkage W 9220 Wiper Blades W 9225 Relay--wiper arm W 9227 (AM 9227) Wiper Blades W 9234 Replace rear window wiper motor W 9242 Rear wiper related W 9254 Washer Hose W 9256 W/S Washer Pump W 9260 Washer Container W 9263 Heater Washer Spray Jets W 9266 Replace washer spray jet W 9272 Replace Headlight Washer Jet W 9401 Aim Headlamps W 9405 R & I Headlight switch W 9415 R & I One Headlight Assy inc Adjust W 9418 Adjust/Aim or Replace Headlight W2 9423 Headlight Bulb W 9429 License Plate Bulb W 9433 Replace one or more taillight bulb W 9435 Replace rear turn signal bulb W 9436 Replace brake light switch W 9437 Brake Light Bulb W 9442 Replace turn signal switch W 9467 Fog Light Bulb AM 9470 Center Brake light bulbs W 9472 Replace Backup light switch W 9475 Back up light bulb (s) W 9528 Dash Light Bulb W 9544 Glove Box Light W 9604 Trunk Light Bulb 9605 Door Jamb Switch for dome lamp 9620 Replace Dome Lamp 9622 Dome Lamp bulb 9628 Dash lamp dimmer 9629 Instrument Panel Light Bulb W 9640 Trunk/Luggage Compartment lamp W 9641 Trunk lamp W 9642 Replace trunk lamp bulb W 9654 Replace heater control light bulb 9715 R F Wiring Harness Probable Repair 9716 RF Wiring harness likely repair parking lamp 9725 Rear wiring harness probable repair W 9739 ECU Wiring harness (like bad ground) W 9740 Ignition Switch wiring W2 9743 Repair or Replace Wiring for Electric Mirrors W 9748 o2 sensor wiring W 9750 Replace ECU wiring for Potential Connections W 9754 Ignition Wiring Transistor W 9758 Speaker Wiring Harness W 9769 Dome Lamp Bulb W 9774 Instrument Panel Harness W 9780 Electric window wiring harness W 9785 Battery Ground Strap 9790 Trans/engine ground W 9794 R & R Fusebox/Circuit Board W 9795 Replace fusepanel |
Some guesses.
This is all based on numerically close-by codes from my list.
AM-0321 is probably a standard service for some interval. W2-9113 is probably something having to do with the radio or nav. AM-0311 is probably a standard service for some interval. W2-6824 looks like it's probably an interior trim item. W2-9170 looks like it's a radio / antenna / speakers item |
