VAG Codes
I don't really understand the codes but I got my car VAG'd to find out why the Traction Control (ESP), ABS and brake lights are on when I am driving. Maybe someone on this forum would have more insight and could assist me as to where and/or what needs to be fixed. Here are the main issue reported from the read out:
Control Module Part Number: 8D0 907 551 AA Component and/or Version: 2.7l V6/5VT G 0003 Software Coding: 06751 Work Shop Code: WSC 63351 4 Faults Found: 16502 - Engine Coolant Temp. Sensor (G62): Signal too High P0118 - 35-10 - - - Intermittent 17887 - Brake Boost Vacuum System: Mechanical Failure P1479 - 35-10 - - - Intermittent 17831 - Secondary Air Injection System; Bank 1: Insufficient Flow P1423 - 35-00 - - 17819 - Secondary Air Injection System; Bank 2: Insufficient Flow P1411 - 35-00 - - VAG-COM Version: Release 504.1-UD Control Module Part Number: 8D0 907 389 E Component and/or Version: ABS/ESP allrad D56 Software Coding: 00000 Work Shop Code: WSC 00000 2 Faults Found: 00778 - Steering Angle Sensor (G85) 66-10 - Not Matched - Intermittent 01044 - Control Module Incorrectly Coded 35-00 - - Anybody have any ideas? |
Re: VAG Codes (Forgot to mention - B5 02 Audi S4, 2.7 V6 Bi-T)
