Sorry to say but, my 1990 Audi Coupe Quattro is up for sale!
<center><img src="http://pictureposter.audiworld.com/20917/102_0295.t.jpg"></center><p>Bought her in November 2004, and spent A LOT of money fixing her up. I never thought the day would come, but I have to let her go.
I am expecting my first child, and the funds for the fixer upper project are no longer available. Below you will find a list of all the fixes and mods that have been done since I bought her. If you are interested, I will email you the Excel Spreadsheet which is less confusing to read than this... Please email me at jirkipi@rogers.com or call (416) 895-9885 Thanks, Paul 1990 Audi Coupe Quattro Repair Log Date Description DTC Mileage O.E. / Aftermarket Nov. 4th / 2004 Purchased Car North Adams, MA. (J. Field) N/A 150055 N/A Nov. 5th / 2004 Repaired 3 Exhaust Leaks N/A 150500 Quick Muffler Nov. 6th / 2004 Replaced Front Rotors & Pads N/A 150500 O.E. & Frisco Nov. 6th / 2004 Replaced Spark Plug Wires N/A 150500 Frisco Nov. 6th / 2004 Replaced Spark Plugs N/A 150500 Frisco - Bosch Nov. 6th / 2004 Replaced Distributor Cap N/A 150500 O.E. Nov. 6th / 2004 Replaced Distributor Rotor N/A 150500 O.E. Nov. 6th / 2004 Replaced Air Filter N/A 150500 Frisco Nov. 11th / 2004 Replaced Rear Rotors & Pads @ Bramgate N/A 150657 Frisco Nov. 11th / 2004 Replaced Timing Belt @ Bramgate N/A 150657 O.E. Nov. 11th / 2004 Replaced Camshaft & Crankshaft Seals N/A 150657 O.E. Nov. 11th / 2004 Replaced Roller/Tensioner @ Bramgate N/A 150657 O.E. Nov. 11th / 2004 Replaced Water Pump @ Bramgate N/A 150657 Frisco Nov. 11th / 2004 Replaced Thermostat @ Bramgate N/A 150657 Frisco Nov. 11th / 2004 Replaced Accessory Belts @ Bramgate N/A 150657 Frisco Nov. 11th / 2004 Replaced Coolant @ Bramgate N/A 150657 O.E. Nov. 12th / 2004 Replaced Washer Fluid Reservoir N/A 150800 O.E. used Frisco Nov. 13th / 2004 Replaced Secondary/Aux. Radiator N/A 150825 O.E. Nov. 15th / 2004 Tinted Windows N/A 150900 Enco Auto Trim Nov. 27th / 2004 Drive Clean @ Active Green & Ross N/A 152155 E- Test - Passed Dec. 1st / 2004 Safety @ Terrifix N/A 152200 Safety Dec. 2nd / 2004 Replaced Fuel Filter N/A 152220 O.E. Dec. 2nd / 2004 Replaced Banjo Screws and Washers N/A 152220 O.E. Dec. 2nd / 2004 Replaced Rubber Grommets for Fuel Filter Holder N/A 152220 O.E. Dec. 2nd / 2004 Replaced L Hose at Throttle Body N/A 152220 O.E. Dec. 14th / 2004 Replaced Windshield Wipers N/A 153400 Cdn. Tire Dec. 14th / 2004 Licensed Car - Plates AVTR-880 N/A 153400 N/A Dec. 14th / 2004 Changed Oil & Filter - 5W 30 N/A 153600 Mobil 1 / Mann Dec. 14th / 2004 Replaced Coolant Reservoir N/A 153600 O.E. Jan. 13th / 2005 Replaced Heater Blower Motor N/A 155200 O.E. Shokan Jan. 15th / 2005 Replaced & Painted Rear Calipers N/A 155300 O.E. Rebuilt Shokan Jan. 15th / 2005 Cleaned & Painted Front Calipers N/A 155300 N/A Jan. 15th / 2005 Bled Entire Brake System N/A 155300 O.E. Fluid Jan. 17th / 2005 Replaced Instrument Cluster 155000 - 248000Km. N/A 248000 Used - Frisco Jan. 23rd / 2005 Rebuilt Power Steering Pump w/ Audi Rebuilt Kit N/A 248000 O.E. Jan. 23rd / 2005 Replaced Mineral Fluid - Pentosin N/A 248000 O.E. Jan. 24th / 2005 Replaced 3 Exhaust Rubber Hangers N/A 248000 O.E. Jan. 27th / 2005 Replaced Driver's Side window Switch N/A 248400 Used - Frisco Feb. 10th / 2005 Replaced Alternator N/A 249650 Rebuilt - Clarkson Feb. 13th / 2005 Changed Oil & Filter - 5W 30 N/A 250000 Mobil 1 / Mann Feb. 17th / 2005 Replaced Oil Pressure Gauge N/A 250200 Used - Frisco Mar. 1st / 2005 Replaced Radio - Clarion N/A 251000 Audiosavings Mar. 1st / 2005 Installed Kaption Speakers to Trunk Lid N/A 251000 KHF Mar. 7th / 2005 Replaced Driver's Side Door Seal N/A 252000 Used - Shokan Mar. 13th / 2005 Replaced Interior Light Bulbs N/A 252000 O.E. Mar. 13th / 2005 Adjusted Windows N/A 252000 N/A Mar. 26th / 2005 Replaced Struts & Springs N/A 254800 Bilstein / H&R Mar. 26th / 2005 Replaced 4 Strut Mounts N/A 254800 O.E. Mar. 26th / 2005 Replaced Front Tie Rods N/A 254800 Aftermarket - Frisco Mar. 26th / 2005 Replaced Front Ball Joints N/A 254800 Aftermarket - Frisco Mar. 26th / 2005 Replaced Front Control Arm Bushings N/A 254800 Aftermarket - Frisco Mar. 29th / 2005 Replaced Rear Lower Door Moldings N/A 255800 O.E. Apr. 3rd / 2005 Changed Oil & Filter - 15W 50 N/A 256500 Mobil 1 / O.E. Apr. 7th / 2005 Replaced Rear Ball Joints N/A 256600 Aftermarket-Shokan Apr. 7th / 2005 Replaced Rear Control Arm Bushings N/A 256600 Aftermarket-Shokan Apr. 7th / 2005 Replaced Rear Sway Bar Links N/A 256600 O.E. Apr. 7th / 2005 Replaced Rear Driver's Side Tie Rod Assembly N/A 256600 O.E. Apr. 7th / 2005 Installed RS4 Replica's w/ Fuzions N/A 256600 Indtuning - Glendale Apr. 11th / 2005 Alignment @ Audi N/A 256682 O.E. Apr. 11th / 2005 Replaced Differential Fluid @ Audi N/A 256682 O.E. Apr. 30th / 2005 Replaced Flex Brake Hoses - Driver's & Pass. Side N/A 259880 O.E. May 2nd / 2005 Installed Cupholder N/A 260040 Aftermarket - VagParts May 9th / 2005 Replaced 5/8" Hose on Power Steering Reservoir N/A 260800 Goodyear - Cdn. Tire May 23rd / 2005 Installed Solid "Mance" Strut Mounts N/A 262200 Aftermarket - Mance May 27th / 2005 Repaired Seized Windshield Wipers N/A 262350 N/A June 1st / 2005 Replaced Accordian Elbow at Throttle Body N/A 262550 O.E. June 3rd / 2005 Replaced Upper Radiator Hose N/A 263550 O.E. June 3rd / 2005 Replaced Heater Control Valve N/A 263550 O.E. June 3rd / 2005 Replaced 4" Rubber Hose - Driver's Side of Engine N/A 263550 Goodyear - Cdn. Tire June 3rd / 2005 Replaced Blown 20amp Fuse - Cooling Fan N/A 263550 N/A June 3rd / 2005 Connected Electrical Contact For A/C N/A 263550 N/A June 3rd / 2005 Changed Oil & Filter - 15W 50 N/A 263700 Mobil 1 / Mann June 13th / 2005 Replaced Fuel Pump N/A 263850 Pierburg - Shokan June 26th / 2005 Repaired Right Rear Tire Puncture - Screw N/A 266000 N/A July 4th / 2005 Installed Resonator N/A 266500 Quick Muffler July 26th / 2005 Installed O2 Sensor N/A 268200 O.E. July 26th / 2005 Rotated Tires N/A 268200 N/A July 26th / 2005 Cleaned ISV N/A 268200 N/A Aug. 3rd / 2005 Replaced Primary Radiator N/A 268900 Precision Tuning - O.E. Aug. 3rd / 2005 Replaced Coolant N/A 268900 O.E. Aug. 20th / 2005 Changed Oil & Filter - 15W 50 N/A 270600 Mobil 1 / O.E. Aug. 20th / 2005 Replaced Coolant Temperature Sensor N/A 270600 O.E. Aug. 20th / 2005 Installed RS2 Lights N/A 270600 O.E. - Ebay Aug. 20th / 2005 Installed B4 Hood N/A 270600 O.E. - Used Aug. 20th / 2005 Installed B4 Radiator Supports N/A 270600 O.E - Used Aug. 20th / 2005 Installed S2 Bumper N/A 270600 O.E. - Europrice Aug. 20th / 2005 Installed S2 Foglights & Turn Signals N/A 270600 O.E. - Europrice Sept. 9th / 2005 Replaced A/C Compressor N/A 272250 O.E. - Elson Sept. 9th / 2005 Replaced A/C Fittings & R134 Oil N/A 272250 O.E. - Elson Sept. 9th / 2005 Replaced Alternator Belt N/A 272250 Frisco Sept. 9th / 2005 Replaced A/C Belt N/A 272250 Cdn. Tire Sept. 9th / 2005 Replaced 20 Cam Lifters N/A 272250 Frisco Sept. 9th / 2005 Replaced Cam Chain N/A 272250 O.E. Sept. 9th / 2005 Replaced Valve Stem Seals N/A 272250 Frisco Sept. 9th / 2005 Cleaned / Rebuilt Cylinder Head N/A 272250 N/A Sept. 9th / 2005 Cleaned Valves N/A 272250 N/A Sept. 9th / 2005 Replaced All Seals & Gaskets - Cylinder Head N/A 272250 Frisco Sept. 9th / 2005 Replaced Spark Plugs N/A 272250 Frisco Sept. 9th / 2005 Cleaned Distributor N/A 272250 N/A Sept. 9th / 2005 Replaced Air Filter N/A 272250 Frisco Sept. 16th / 2005 Replaced Crank Pulley - 6061 T6 Aluminum N/A 272250 Dad's Creation Sept. 29th / 2005 Replaced Oil Pump Gasket N/A 272400 O.E. Sept. 29th / 2005 Repaired Oil Pan N/A 272400 Precision Welding Sept. 29th / 2005 Replaced Oil Pan Gasket N/A 272400 Frisco Sept. 29th / 2005 Replaced Small Oil Pan Gasket N/A 272400 O.E. Sept. 29th / 2005 Replaced Timing Belt N/A 272400 Frisco Sept. 29th / 2005 Replaced #1 & #2 Fuel Injectors N/A 272400 Used Sept. 29th / 2005 Cleaned Oil Pick Up Tube & Strainer N/A 272400 N/A Sept. 29th / 2005 Replaced Oil Pick Up Gasket N/A 272400 O.E. Sept. 29th / 2005 Replaced Oil Pick Up Black Plunger N/A 272400 O.E. Sept. 29th / 2005 Changed Oil & Filter 15W-50 N/A 272400 Mobil 1 / Clean Oct. 14th / 2005 Replaced Oil Pump N/A 272400 O.E. Oct. 14th / 2005 Replaced Oil Pressure Spring N/A 272400 O.E. Oct. 14th / 2005 Replaced Oil Pressure Piston N/A 272400 O.E. Oct. 14th / 2005 Replaced Crankshaft Seal N/A 272400 O.E. Oct. 14th / 2005 Replaced Roller/Tensioner N/A 272400 O.E. Oct. 14th / 2005 Replaced Oil Pick-Up Tube N/A 272400 O.E. Nov. 23rd / 2005 Replaced Knock Sensor #1 2134 274180 O.E. Nov. 23rd / 2005 Installed Winter Wheels & Tires N/A 274180 Steelies + Ultra Grip Nov. 25th / 2005 Replaced Passenger Front Wheel Bearing N/A 274500 Frisco Nov. 25th / 2005 Changed Oil - No Filter N/A 274500 Castrol / O.E. Dec. 11th / 2005 Replaced Rear Hatch Struts N/A 278000 Autohaus AZ Dec. 11th / 2005 Replaced Steering Wheel & Hub Adapter N/A 278000 Momo / Nardi Dec. 11th / 2005 Replaced Oil Pressure Sender N/A 278000 Autohaus AZ Dec. 31st / 2005 Installed Sirius Satellite Radio N/A 279000 Sirius Dec. 31st / 2005 Replaced Passenger Window Switch N/A 279000 Used - Frisco Jan. 4th / 2006 Replaced both Washer Nozzles (Non-Heated) N/A 279000 O.E. Jan. 14th / 2006 Replaced Oil Pan Gasket N/A 280000 Frisco Jan. 14th / 2006 Changed Oil & Filter 10W-30 N/A 280000 Mobil 1 / O.E. Feb. 22nd / 2006 Replaced Both Front Inner & Outer CV Joints N/A 285000 Reman. Feb. 22nd / 2006 Replaced All 4 Control Arm Bushings N/A 285000 Frisco Feb. 22nd / 2006 Replaced Alternator N/A 285000 Clarkson |
i'd buy that. very nice.
...for the lazy...
<IMG SRC="http://pictureposter.audiworld.com/20917/102_0287.jpg">
<IMG SRC="http://pictureposter.audiworld.com/20917/102_0295.jpg"> <IMG SRC="http://pictureposter.audiworld.com/20917/102_0296.jpg"> <IMG SRC="http://pictureposter.audiworld.com/20917/102_0298.jpg"> |
Thanks for that!!!!!!!!!!!!!!!!!!!!!!!!!
Might as well show the beauty off! ;o)
Still can't figure out how to post multiple pics.......I'll leave that up to you :op
Can you do that on the Canadian Forum as well.............please!
good lord. if it came with a 20vt i'd sell my A4 for it in a heartbeat.
considering it even as it stands ;-)
that is an unbelievably beautiful car... congrats on the fatherhood! |
Thanks for the kind words :o)
obviously ;)
