Upper Radiator Hose Removal
Old 11-30-2012, 09:55 PM
05audiA6's Avatar
Default Upper Radiator Hose Removal
Hello,
New here, I have a 05 A6 and I broke the nipple off of my upper radiator hose (see pic) so I've ordered the new hose, but I've never seen this type of coupler before. How do I remove this hose? I'm sure it's something simple, but before I destroy the radiator I thought I'd ask.
I've looked through the forum and didn't see anything but if I missed it, please point me in the right direction.
Thanks,
Russ
Old 12-01-2012, 02:16 AM
royclark's Avatar
Originally Posted by 05audiA6
Hello,
Thanks,
Russ
I can't see much detail on your picture. Is this the setup?
<TABLE cellSpacing=0 cellPadding=0 width="100%"><TBODY><TR><TD class=spalte-text><TABLE class="cc abstand-kap einzug-standard"><TBODY><TR><TD class=titel-kap></TD></TR></TBODY></TABLE>Removing</TD></TR></TBODY></TABLE>
<TABLE cellSpacing=0 cellPadding=0 width="100%"><TBODY><TR><TD class=spalte-text><TABLE class="cc einzug-standard abstand-standard "><TBODY><TR><TD class=einzug-liste>– </TD><TD>Lift retaining clip -arrow- and disconnect coolant hose (front left) from radiator.</TD></TR></TBODY></TABLE></TD></TR></TBODY></TABLE>
<TABLE cellSpacing=0 cellPadding=0 width="100%"><TBODY><TR><TD class=spalte-text><TABLE class="cc bild-titel einzug-standard abstand-standard"><TBODY><TR><TD>Connecting coolant hose with plug-in connector</TD></TR></TBODY></TABLE><TABLE class="cc einzug-standard abstand-standard "><TBODY><TR><TD class=einzug-liste>– </TD><TD>Remove old O-ring -2- from coolant hose -3-.</TD></TR></TBODY></TABLE><TABLE class="cc einzug-standard abstand-standard "><TBODY><TR><TD class=einzug-liste>– </TD><TD>Lightly lubricate new O-ring with coolant and fit O-ring in coolant hose.</TD></TR></TBODY></TABLE><TABLE class="cc einzug-standard abstand-standard "><TBODY><TR><TD class=einzug-liste>– </TD><TD>Press coolant hose onto connection -1- until it engages audibly.</TD></TR></TBODY></TABLE><TABLE class="cc einzug-standard abstand-standard "><TBODY><TR><TD class=einzug-liste>– </TD><TD>Press coolant hose in again and then pull to check that plug-in connector is correctly engaged.</TD></TR></TBODY></TABLE></TD></TR></TBODY></TABLE>
A19-10572.png?t=1354360468
Old 12-01-2012, 05:49 PM
05audiA6's Avatar
Yes, that helps a lot. The nipple snapped off with hardly any pressure, so I'm glad it happened in my driveway and not on the road.
Old 04-17-2013, 03:12 PM
AWJ277's Avatar
Default Thanks!
Thanks guys, this thread really helped me out.. The nipple on my radiator hose broke off as well and I freaked seeing all of the antifreeze leaking out of my car, but it's all fixed now thanks to this thread!
Thanks Again
a6wrenchin
10
10-14-2015 07:10 PM
SPETRUZZI
12-17-2011 09:19 PM
cghelani
08-01-2006 02:17 PM
Ramoner
03-08-2006 03:39 AM
visintainer [vis]
02-02-2006 10:55 AM
Quick Reply: Upper Radiator Hose Removal
