I presume TPMS can be turned off w/VAG-COM?
Old 06-21-2014, 03:33 AM
stuffinder's Avatar
Default I presume TPMS can be turned off w/VAG-COM?
Will most likely run older AVUS w/225/55x16 Hakka R2's on newly acquired '06 A6Avant and don't want to stare at TPMS warning all winter!
Any link to procedure appreciated! MMI Software is up to date. TIA
Will be test fitting AVUS 16's for clearance in week or two.
Old 06-21-2014, 03:51 AM
uberwgn's Avatar
Someone claims to have finally found a way to turn it off on the '06 car. We need to find the thread.
Let us know if the Avus wheel fits. There are very few 16" wheels that do.
I think I mentioned to you in the other thread that Gary at Tire Rack knows which wheels bolt up. He sold us the RIAL Como in the 16" size:
Old 06-21-2014, 03:55 AM
uberwgn's Avatar
Old 06-21-2014, 10:04 AM
mavila's Avatar
Newbie/dumb question, but do all the C6s have TPMS?
Old 06-21-2014, 11:40 AM
KevinGary's Avatar
No
Old 06-21-2014, 03:12 PM
raj99's Avatar
Originally Posted by KevinGary
No
Kevin, I thought all C6s had TPMS, whether passive or active...am I mistaken?
BTW, for the OP do a search under 'disable TPMS' and you'll find threads on how to do it. or spend the $150 for 4 new TPMS and save yourself the headache.
Old 06-21-2014, 05:20 PM
KevinGary's Avatar
TPMS was a stand alone option in 2005. The base car did not have it.
Old 06-23-2014, 04:37 AM
frankinstyn's Avatar
Check out this thread. It definitely can be done as I've done it on my 2006 Audi A6.
I had to both disable it using Ross Tech and take out the fuse. Haven't heard a peep from it for 9 months.
Use Ross Tech to disable TPMS (Tire Pressure Monitoring System) - go to Instruments (17), Adaptation, Channel 61
http://forums.fourtitude.com/showthread.php?4756487
It's in controller 17-Instruments.
Simply subtract 16 from the number in the first four digits and it should disable the TPMS.
ALWAYS REMEMBER to write down the original code before making any changes in case you have a problem or need to change it back..
Old 06-24-2014, 07:47 AM
LLskier23's Avatar
Disabling TPMS is doable via VCDS. I had to disable it in multiple places, including the Instruments (17) and the Control Head (09 --> channel 01). Also, it took multiple attempts at this and had to be done in a certain order before I eventually was successful. Play around with it and make sure to document all your changes as mentioned above.
Of note, Avants like mine with the power liftgate get power to the hatch motors through the same fuse as the TPMS. That means removing the TPMS fuse wasn't an option for me, otherwise I couldn't open my hatch. I think that's why I had to disable the TPMS in multiple controllers but eventually got it to work. I never plan on turning TPMS back on at this point.
Old 06-24-2014, 07:49 AM
I didn't realize that. My lowly avant doesn't have the power lift gate. :-(
CURSH[silverbullet]
09-28-2006 10:35 AM
MikeL
Audi Original "S" Cars
10-08-2005 01:36 PM
SCarGo02
13
08-19-2005 05:25 AM
DOC
Wheels & Tires Discussion
04-28-2003 01:39 PM
Greg Davis
01-17-2000 08:10 PM
Quick Reply: I presume TPMS can be turned off w/VAG-COM?
