A4 3.0 Quattro new owner have Eng Code ???
Old 03-25-2014, 02:22 PM
CrazyFast383's Avatar
Default A4 3.0 Quattro new owner have Eng Code ???
JUST bought my 1st Audi not even 2 months ago. Picked up a '03 A4 3.0 Quattro and LOVE IT!!! Has 158k on it but looks new! Already had to put a front dr side wheel bearing and CV shaft in it. Now the check eng. light is on. Had it scanned at Autozone and 3 codes popped up. I'm very mechanically inclined, just need some help on where to start with these codes.
1. Charcoal canister/purge valve
2. AIS
3. Clutch solenoid
1. Fixed (I read you can basically over fill the tank when refueling and that can fix it)... and it worked!!!
2. AIS... I had this system on my bike. Everyone (including myself) removed the pump and tubing because it cause 'popping' on decel when aftermarket pipes where installed. Is the AIS a common issue and what are the steps in diagnosing this?
3. Car runs, drives, shifts great! No issues! Why would this code pop????????
Old 03-25-2014, 08:51 PM
A4Audi4Fun's Avatar
Clutch solenoid might be an old code; don't know why it would register as a CEL - clear it and see if it comes back.
Old 03-26-2014, 04:24 AM
lyleswk's Avatar
So the CEL is gone? If so, leave the car alone. If not, get a VAGCOM download so you can narrow down the issue. The generic readers can be misleading on AUDIs.
Old 03-30-2014, 05:06 PM
Sorry so what is a CEL? Used my dad's scanner and it was a bit more informative. The AIS was from Bank 2. Looked through the pile of oil change/service receipts in the glove box to see that the AIS bank 2 code came up before. Mechanics replaced a seal with a "used part".
The clutch solenoid code came through as basically the torque converter not locking up. We cleared all codes and about 15 miles eng light came back on. Haven't had a chance to scan it again yet.
Old 03-31-2014, 07:22 AM
lyleswk's Avatar
CEL = Check Engine Light.
Did you write down the code numbers? That is helpful.
dlin6467
A4 (B7 Platform) Discussion
04-11-2017 03:30 PM
ANTSINNZ
New Member Welcome Area
04-09-2017 05:00 PM
Coachcabe
08-25-2007 11:49 AM
jayel
09-08-2005 09:43 PM
europe
08-11-2004 10:28 AM
Quick Reply: A4 3.0 Quattro new owner have Eng Code ???
