What the #!&? How do you remove the plastic lug nut covers?
Old 04-25-2001, 04:22 AM
SGP
SGP's Avatar
Default What the #!&? How do you remove the plastic lug nut covers?
Is there a special tool (that may be missing from my tool pouch)? Thanks.
Old 04-25-2001, 04:36 AM
Longwolf (Christian)'s Avatar
Yea, should be a tool in the kit that looks somewhat like wide tweezers.
Greyhound Guy's Avatar
There is a tool but you dont really need it. Just use whatever and be careful.
Head Cat Herder
Kris Hansen's Avatar
Default The tool is a plastic U shaped deal, use it to hook onto the caps and pull.
you can pry them off (carefully) with a screw driver if need be.
Andy Hedin's Avatar
Default Your tool kit should have included this tool.....
<img src="http://pictureposter.audiworld.com/116/lugbolt-cover_removal_tool.jpg">
This is the correct tool to use to remove the plastic lug-bolt covers. Snaps onto the covers and pulls them right off with no contact to wheel itself. Your dealer will probably give you one if you tell them yours was missing from your A4.
Old 04-25-2001, 04:42 AM
Matt H.'s Avatar
Regular screwdriver works but be careful!
Old 04-25-2001, 04:54 AM
SGP
SGP's Avatar
Default You da man!
I bought the car used; the tool kit has a u-shaped metal tool that my wrench imediately identified as the tool for prying off a moon-style chrome hubcap from a 1960's vintage porsche! And it doesn't work for the A4!
Old 04-25-2001, 04:59 AM
Andy Hedin's Avatar
Default That U-shaped metal tool (which I have as well) was used to pull the center caps off of certain....
....wheels. I believe it fits the 15" wheels that have one big cap in the center which hides all the lugbolts. Using that tool to remove the 5 plastic lugbolt caps will cause scratches on your wheels.
Old 04-25-2001, 08:17 AM
audiohs's Avatar
I use needle nose pliers. I got the plastic tool mentioned below from the dealer-doesn't cost much
Old 04-25-2001, 11:09 AM
Stang Guy's Avatar
I bent a big paper clip into a useable U shape to remove them w/out scratches
tommoran2
A4 (B9 Platform) Discussion
11
06-27-2018 05:07 PM
Kingate
03-11-2004 02:57 PM
S4 Vince
10
06-03-2002 03:57 PM
konyo
10-23-2000 11:22 AM
BOBP
02-26-2000 06:55 AM
Quick Reply: What the #!&? How do you remove the plastic lug nut covers?
