front suspension squeaking when hitting bumps and when turning wheel at stop
Old 05-24-2008, 12:17 AM
kevinvu34's Avatar
Default front suspension squeaking when hitting bumps and when turning wheel at stop
both side of suspension squeak when I hit any bump or change in road level...when car is parked, turning steering wheel will cause a squeak on right side if turn right and when turn left, it's squeak left...best way of describing how it sound like would be a squeaky door...please help
Old 05-24-2008, 06:20 AM
Banned
CTA4AVANT's Avatar
Default You probably need to grease your control arm bushings.
<center><img src="http://www.b2bgreaseguns.com/rimages/533/Ga-001s.jpg"></center><p>Get the following:
1) A grease gun.
2) A tube of Mobil 1 Synthetic grease.
3) A small diameter grease gun injector needle (Pictured).
All you have to do is poke the grease gun needle into the control arm bushing and give a few pumps of grease into each bushing.
Done.
Worked for me. No squeaks in 100K miles.
Old 05-24-2008, 06:37 AM
ski ya later's Avatar
or outer tie-rods.
Old 05-24-2008, 04:30 PM
kevinvu34's Avatar
Re: thank you very much for the advice...can you tell exactly how many bushing I have to inject...
Old 05-25-2008, 08:03 AM
CTMechE's Avatar
Default Re: front suspension squeaking when hitting bumps and when turning wheel at stop
My tie rod ends squeaked like a rusty gate when I turned the steering wheel at parking lot speeds. That's when I noticed the bushing seals had failed. Give 'em a look.
Old 05-25-2008, 10:26 AM
kevinvu34's Avatar
Default bushing seal?
where exactly are the bushing seal located...I have an idea but want to make sure I'm right...thanks
couper83
6
02-04-2007 06:26 PM
backdoc
04-22-2004 02:05 AM
AaronBryan
04-07-2004 05:09 PM
lanks1.8t
03-20-2002 07:28 AM
malish
09-11-2000 11:51 AM
Quick Reply: front suspension squeaking when hitting bumps and when turning wheel at stop
